painting shock bodies
Old Mar 13, 2007 | 02:06 PM
rsylvstr's Avatar
rsylvstr
I plan on painting my RSX's before installing.
what paint should i use to ensure the original paint won't peel off?
Old Mar 15, 2007 | 05:47 PM
mrl390's Avatar
mrl390
Scuff down and apply a rust inhibiting primer. Then paint over the primer. A coat of clear wouldnt hurt either.
Old Mar 15, 2007 | 06:38 PM
rsylvstr's Avatar
rsylvstr
heck, they have a nice paint job already....just want to see about a clear coat.
Old Mar 16, 2007 | 01:54 PM
rsylvstr's Avatar
rsylvstr
bump....
thinking clear gloss polyurethane spray
Old Mar 17, 2007 | 07:51 AM
teds74ford's Avatar
teds74ford
So...what are you asking? I think you want to know what kind of clearcoat to get. Based on that, lightly sand the body with 600 grit and spray some rustoleum clear on. Repeat.
Just so you know, rattle can clear is tricky. I have been able to do well on small parts, but when I cleared my whole truck, it came out awful. I have years of experience with spray, but if you don't, you might not like the results.
It is like spraying water and hoping it doesn't run- and too light leaves it grainy. When you are spraying, as soon as it looks shiny move on.
Old Mar 17, 2007 | 03:34 PM
rsylvstr's Avatar
rsylvstr
thanks...wasn't sure if polyurethane was the best choice, that's all.
I've clearcoated wood before LOL....
will it make the stickers peel off the shock body?
Old Mar 20, 2007 | 07:37 AM
teds74ford's Avatar
teds74ford
I wouldn't clear over the stickers.
Old Mar 20, 2007 | 07:42 AM
rsylvstr's Avatar
rsylvstr
what about clear tape over the stickers, then paint?
hate to have the body of the shock look good and the stickers falling off.
Old Mar 22, 2007 | 08:14 AM
teds74ford's Avatar
teds74ford
That I don't know. My shocks don't have stickers on them. I would think the stickers would make the clear "pull" at their edges.
Old Mar 23, 2007 | 08:06 AM
roger dowty's Avatar
roger dowty
ocd? :-) I checked you out and didn't see any pics of your rig...just engine. you could remove the stickers and get some paint from por that would make them look like their gold plated. The shock will rust on the inside of the cylinder unless you treat it as well...then stain whatever is on the outside.
rattle can clear has a very low solid count thus the poor result when using it over a large surface- i'd apply numerouse light coats with intermittent flash times- kind of like old lacquer; but not.
How did the ps seals work out?
Old Mar 30, 2007 | 10:09 AM
rsylvstr's Avatar
rsylvstr
not sure what i was thinking, but didn't get ployurethane....
I got clear enamel....hope this works!
figure i need to (?) scuff with 200 grit sandpaper, then 2-3 light coats? or will that make them look like crap, scuffing the paint that came on them?
abe
Feb 21, 2017 09:58 AM
abe
May 20, 2016 12:57 PM
vidaliaman
Paint & Bodywork
Apr 14, 2016 11:46 AM
SouthernBlues
Aug 18, 2015 05:08 PM
dbrown13
1983 - 2012 Ranger & B-Series
15
Apr 23, 2007 01:57 PM
