I have 97 explorer xlt automatic. yeah, i couldn't get it out of park until i looked in the manual about the brake-shift interlock and how to avoid that. is the brake light switch an easy fix?
a seperate fuse works the 3rd brakelight and the fuse that works the other brake lights also controls the cruise control, anti lock brakes and the 4 wheel drive.
you have had to step on the brake pedal since the early 80's in most vehicles.
you have never driven any other vehicle that needed you to step on the brakes to get out of park?
Meter out the fuse to verify that it is functional. Chen meter out the brake light switch for continuity. Jump the brake light switch with a jumper and see if the brake lights turn on.
My Explorer doesn't require you to stop on the brakes to get out of park. I'm sure that its not supposed to be like that, but it doesn't bother me at all.
Quicklook, thats exactly right but all those items are powered from the brake light switch. They only have voltage to them when the brakes are applied.
As you said earlier this could be a blown fuse.
Logan take another look at interior fuse 13.
Is it blown??
They are on the same circuit. You are over analyzing this, a simple check with the DVOM will determine whether or not the switch is bad.
