1978 - 1996 Big Bronco
A little help with my Bronco...
Old Aug 24, 2002 | 04:19 PM
BroncoGuy88's Avatar
BroncoGuy88
Hello, I have a 1988 Bronco, with a 302 motor and an Automatic Transmission. For some reason, the Automatic Overdrive will not shift out of low gear. Does anyone know why this would happen? Thanks in advance.
Old Aug 27, 2002 | 04:51 AM
broncn_rick's Avatar
broncn_rick
Are you having the same problem that I am having? In my 95' XLT 4x4 5.0 with AOD and whenever I get the RPM's over 3500 and the engine will seem like it jumps the RPM's up to near max until I lay off of the gas a bit then it catches and gives a little kick. The tranny works in all gears, the AOD works fine if i kick it in before 3500 RPM. I was told it might be a fuel filter problem. After I replaced the fuel filter the truck now waits to about 3800 RPMs to do the same thing. When the RPM's kick up I dont get the increased acceralation but the car will maintain its moderate accelaration. Does anyone have any suggestions? Please help.
Old Aug 27, 2002 | 08:19 PM
luv mt truck's Avatar
luv mt truck
Post A little help with my Bronco...
TN boy sounds like the tourqe converter to me but take your trucks to a tranny shop to make sure before you pull the tranny
Old Aug 28, 2002 | 04:10 AM
broncn_rick
to luv mt truck were you replying to me? Broncn_rick
Old Aug 28, 2002 | 03:35 PM
luv mt truck
TN boy i was replying to both of you i have seen tc"s cause both problems my 94 bronco EB 351 AUTO had a tc problem so i removed the tc and had it rebuilt put it back and that fixed that
Old Aug 28, 2002 | 04:18 PM
Steve_Uzi's Avatar
Steve_Uzi
ET2
All Things Towing
Mar 9, 2018 09:50 PM
ty.jordan
Jul 12, 2017 09:58 AM
Caleb Cook
28
Apr 6, 2017 05:30 AM
Big Betsy
Oct 12, 2003 02:24 PM
joeyv821
Oct 27, 2001 12:44 PM
