Flathead + 4 speed tranny suggestions
Old Mar 1, 2007 | 06:54 PM
thendrix's Avatar
thendrix
Got a 48 F1. Want to use a Flatty with a four speed trans. Does anybody have any suggestions? I have seen a thread recently talking about a Warner T something being a direct bolt on to a Flatty. Any help is greatly appreciated.
Old Mar 1, 2007 | 07:16 PM
jimhackney's Avatar
jimhackney
4 spd Flatty
Here's a discussion you might find useful
http://www.jalopyjournal.com/forum/a...p/t-46109.html
bobj49f2's Avatar
bobj49f2
You can mount a T-5 behind a flattie either by buying a kit from a place like Speedway Motors or you could make your own using the "Hogshead" from a F-2 and up Ford truck. There has been a lot of discussion about this conversion on this site. Since you are a new member you won't be able to use the search feature of the site so do a Google search using terms like "transmission" "adapter" or "T-5" and then insert this sites url in the domain box on the search page. You should find a lot of leads.
You can also use the transmission from a '85 and up Ford F-150.
Old Mar 1, 2007 | 08:26 PM
reamer's Avatar
reamer
I found a T-98 syncroed tranny, (not a crashbox) bolted right-up to my 239 Flathead. lined up to the cross member too. No adaptor plates needed!
Old Mar 1, 2007 | 08:35 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Reamer, is the T-98 a 4-sp or what? What year did you put it in?
Old Mar 1, 2007 | 09:37 PM
reamer's Avatar
reamer
Yep, 4-sp. 4th is 1-to-1.
Rear mount holes even lined up to the original crashbox crossmember holes.
Clutch lever, and e-brake lined up too!
Talk about a perfect bolt on fit!
Got the T-98 from Chuck at Chucks Trucks, (203 288 2769)
He may still have another one on the shelf!
And I also bagged a Browney box on ebay for Overdrive!
With the Eaton 2-sp rear sporting 5:83 in high, Solid rims and 9R-22.5 radials and a Browney box, 65 may be No problem for this 1948 F-5.
This will probably be the first time ever this thing will go over 40 MPH!
Cool or what????
Old Mar 1, 2007 | 09:55 PM
thendrix's Avatar
thendrix
Thanks everybody for the info. I just have one more question, and at the risk of sounding dumb, what is a "crashbox"?
Old Mar 1, 2007 | 10:39 PM
1952henry's Avatar
1952henry
a non -synchro-ed transmission. T98s were found in Ford trucks clear up 'til the early 60s. I here tell that the input shaft splines were the same from Y-blocks to flatheads, at least on the three speeds.
Old Mar 1, 2007 | 11:34 PM
51ford fan's Avatar
51ford fan
I drove my 51F1 for a year with that lousy Crashbox and 4.27 gears in it. Then I installed an 89 S-10 5 speed and 9" rearend with 3.23 gears. That trans is great it made that truck a pleasure to drive again. Look in my pictures I put some pictures of the install there
Old Mar 2, 2007 | 07:51 AM
reamer's Avatar
reamer
Crashbox = double shifting, = lots of gear grinding
Old Mar 2, 2007 | 10:26 PM
51ford fan's Avatar
51ford fan
Crashbox = double shifting, = lots of gear grinding = Pain In The A** here in the city of Seattle. Guess you can tell I love that 5-speed huh, it really made that truck a pleasure to drive.
Old Mar 3, 2007 | 05:42 PM
bobj49f2's Avatar
bobj49f2
I concider the non-syncro 4 speed as a anti-theft device. I love watching someone who has never driven one try to drive it. I personally don't mind the tranny. I don't even double clutch it anymore, except around corners. I just listen to the engine and shift.
Old Mar 4, 2007 | 02:11 PM
pcmenten's Avatar
pcmenten
So, I don't think you question got answered.
There is a bellhousing that fits light-duty 3sp transmissions. The trans bolt pattern is sometimes called 'narrow'. And there are top-loader and T-10 four speed transmissions that have this narrow bolt pattern. Be aware of input shaft length differences; truck transmissions tend to have longer input shafts.
Many top-loaders have a 1-1 fourth gear. Later top-loaders and the SROD have an overdriven fourth gear and third gear is 1-1.
There are top-loaders that came in Jeeps, T-176 for example, that have a shifter that bolts to the top of the transmission. This is a nice option because the shifter will clear the seat. A problem with the T-5 conversion is getting a tailshaft/shifter setup that clears the seat. The Mustang World Class T-5 has its shifter back on the tailhousing and doesn't fit well. The S-10 T-5 transmission has its shifter farther forward and fits better, but it isn't as strong as the Mustang WC T-5.
Short answer; what you're asking about it the top-loader 4 speed transmission.
Old Mar 4, 2007 | 02:59 PM
1952henry's Avatar
1952henry
An answer=T98.
Old Mar 4, 2007 | 05:22 PM
59flatbedford's Avatar
59flatbedford
too bad your so far away i must have half a dozen t98s laying around here and there.
