66 F-100 Leaf Springs
Old Feb 11, 2007 | 08:50 AM
carras's Avatar
carras
I'm looking at replacing my leaf springs. I found a place local where they sell sets from 1973 and newer. They mention that the '73s are either 2.5" or 3" wide and 5 leaves. Mine are 5 (plus 2 thicker ones at the bottom) and measure 2.25" wide. My questions are: 1. Are the measurements similar to lumber where they round up? 2 Will the '73's fit my 66?
Thanks in advance for the help.
Old Feb 11, 2007 | 08:52 AM
jeepbut's Avatar
jeepbut
A local spring shop can make them as soft or as stiff as you would like. Thanks, Lyman.
Old Feb 11, 2007 | 01:56 PM
carras's Avatar
carras
Thanks, I'll try the local spring shop. The reason why I was interested in knowing was because the parts place that I was looking at had them for $95 per side for the 2.5" wide.
Old Feb 11, 2007 | 02:27 PM
carras's Avatar
carras
I did a bit more digging and found in the NPD catalog that the 66 was truly 2.25". I would probably have to change the shackles to use the 2.5"s. Oh well will have to pass on the $95 'deal'
Thanks again
Old Feb 11, 2007 | 07:10 PM
fast frank 66's Avatar
fast frank 66
ask about having yours re-arched
Old Feb 11, 2007 | 11:46 PM
airharley's Avatar
airharley
Re-arching them is a possibility as long as there isn't too much wear between the leafs. My rear leafs, which I think are the original ones, have a .040 deep spots worn into them from the suspension moving around the last 40 or so years. I did find this site that sells them for $109-114. Just be sure to measure the length of the springs in front and behind the spring perch to get the right ones. I am also unsure if it's just the primary or the whole leaf stack. The price would suggest it is only main leaf though.
http://leafspringstacks.generalspringkc.com/ford.html
Old Feb 12, 2007 | 01:05 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Exclamation 5560 F100
1965/72 F100 2WD Rear Springs (as originally equipped)
1965/69: 5 Leaf: C5TZ-5560-A .. Width: 2 1/4" / Depth: 1 5/8"
1968/72: 5 Leaf: C8TZ-5560-A .. Width: 2 1/4" / Depth: 2"
1966/69: 6 Leaf: C5TZ-5560-N .. Width: 2 1/4" / Depth: 1 15/16"
1968/72: 6 Leaf: C8TZ-5560-C .. Width: 2 1/4" / Depth: 1 23/32"
1965/69: 9 Leaf: C5TZ-5560-D .. Width: 2 1/4" / Depth: 2 19/32"
Wax inserts and liners are available for all rear leafs.
Old Feb 13, 2007 | 07:55 AM
carras's Avatar
carras
thanks for the additional info. my springs are badly worn as well so re-arching is not an option. Thanks for the website and the ford numbers. I now have all the info that I need to make the right purchase. I appreciate everyone's support
Old Feb 13, 2007 | 10:20 AM
BikerDude's Avatar
BikerDude
Eaton Springs
Check out www. eatonsprings.com They make springs for a living and can make them in whatever capacity you need, standard or reverse eye, lowered, ect. Prices seem fair as well to me for a quality product. When I replace mine I'm going with them.
armyaviation
Oct 19, 2012 02:16 PM
breno1987
Aug 24, 2011 07:39 AM
66crawler
Offroad & 4x4
20
Sep 2, 2010 10:36 AM
quadzjr
Offroad & 4x4
21
Jan 3, 2007 10:56 PM
69crewcab
Jul 26, 2002 07:54 PM
