NP435 tranny question
Old Feb 10, 2007 | 08:02 AM
jd_sylvia's Avatar
jd_sylvia
My Np 435 tranny is seeping gear oil out from under the rubber boot in the cab. It is not a lot of oil but it is a bit anoying. Should the boot fit tight enough to seal this or is this normal for this tranny.
Old Feb 10, 2007 | 08:17 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The boot is supposed to fit tightly around the shift lever. Ford doesn't call it a seal, but if it's worn, it's possible oil is finding its way up the lever, then onto the floor.
B8T-7277-A Shift Lever Boot NP 435
Old Feb 10, 2007 | 08:24 AM
jd_sylvia's Avatar
jd_sylvia
It is filled to the proper level ( a bent finger tip below the threads of the fill hole)
I think I might try a synthetic gear oil to reduce foaming, but these old trannys probably have a lot of splash to get everything lubed.
Thanks for the help..
Old Feb 10, 2007 | 08:26 AM
NumberDummy
^^^Revised^^^^
btw..ever had cars in a magazine? your name is familiar.
Rasputin53
Dec 17, 2013 05:56 PM
OzFTrucker
Nov 30, 2013 12:44 AM
Unimog005
13
Aug 21, 2005 12:48 PM
broncorule
1978 - 1996 Big Bronco
Jul 18, 2003 10:07 AM
