I'm going to be changing from original single intake to this edmunds setup.
Question is what do I use for the fan adjustment on the new setup?
I will most likely use an electric fan, but the bolt hole on the front of my current single intake has a dual bracket the tensions the water pump belt, and the generator.
I know I need to move the generator to fit the 2 94 carbs, but what part name is the new piece that I need for the water pump belr adjustor?
thanks
