I'm installing a new radio/cd in the middle on my'56 dash. The radio will block the cowl vent operation handle. I won't need the vent because it has Air. I don't want to weld the vent close but how do I secure the vent so it doesn't leak.
The PO (previous owner) of my 56 did the same thing. He removed the handle and bent the bracket over, then secured the cowl vent with silicone sealer to keep the rain out. It worked fine to keep things dry.
If I wanted the same thing you do, I would also use the silicone sealer, but I would remove the bracket assy and just leave the cowl vent and its arms in the hole.
You could also install an electric cowl vent motor, eliminating the handle but still have an operable cowl vent with the flip of a switch. The cowl vent is still nice to have on those days that aren't warm enough for a/c yet.
Scott123 That's a cool idea about an ele motor on the cowl would you like to elaborate on how and what kind. Mine is bent the handle that is and does'nt operate so smooth. RUSTY
It is used to open/close cowl vents, glove boxes, gas doors, etc. It lists for $59 at this company, but I got mine from a now out-of-business company for half that (maybe why they went out of business?)
I did see that Classic Auto Parts in OK City has one specifically for cowl vents that was around $90: classic cowl vent
The unit I used, I completely removed the old handle (not used anymore) and mounted the linkage to the vent assembly and to a brace on the cab near the vent opening. I had to get a longer threaded rod for it to all work out, and it took a couple of evenings of cussin' and drinkin' to get it lined out, but I now flip a toggle up and the vent opens, toggle down and it closes.
Scott123 Yea that's kool Classic parts is only about 10 miles from my house I'll have to make a note of that.Man I've got lots of notes. And a long ways to go yet. Thanks RUSTY
I have an electric cowl vent motor on my 53. It is wonderful on those cool mornings and also when the cab is really hot from setting in the sun it will help move the hot air out so the A/C can do it's job.
I bought the electric unit kit from Sacramento Vintage Ford for my 54. I wanted to install the Rod Doors system under the dash, but I could not use the vent handle. It is very cool to watch the look on people's face when the vent raises and lowers. Good luck, Jag
I have purchased items from Rocky Hinge Co. which have always been good quality. He offers a power cowl vent setup for $80. I have not used it but plan to on my next project. www.rockyhinge.com
