Its on my 50 what is it ?
Old Dec 3, 2006 | 09:49 PM
TryMe's Avatar
TryMe
On the right side of my firewall On my 50 F-6. I have what looks like a
plumbers cast elbow a little. It has 2 fittings on it with two 3/4" heater
hoses on it. Most of it is on the out side,but the is part of it that goes
into the inside. The part that goes on the inside has a screw adjustment
on it. Here is what I am thinking but I am not sure. Im thinking its some kind if a valve for the frame mounted brake booster. But I am not sure ,whats the adjustment screw for? Do I need it ? Do they go bad ? I was cleaning up
my firewall,and was thinking about removing it,or just at least moving it
some were it would not be seen. Any ideas ?? Thanks.
Old Dec 6, 2006 | 12:34 PM
cabby daddy's Avatar
cabby daddy
if you look along the frame to the back of the truck, you will probably fidnd more tubing. sounds like vacumm tubes for vacumm trailer brakes,,,...
Old Dec 6, 2006 | 05:20 PM
bigwin56f100's Avatar
bigwin56f100
I believe it is a check valve for the power brakes, My f-600 has one on the firewall too.
Kevin Bigwin
Old Dec 6, 2006 | 05:30 PM
WALFORD'S 56's Avatar
WALFORD'S 56
bigwin--I think your correct.Mine goes to a filter in the cab and to the booster underneith too.I always wondered same thing. Bill
Old Dec 6, 2006 | 07:50 PM
TryMe's Avatar
TryMe
Thanks guys for the information. Tracy
Old Dec 6, 2006 | 07:52 PM
51PanelMan's Avatar
51PanelMan
I believe that it's a vacuum system for the brake booster. I found the same thing, routed the same way as described, on my 52 F6 when I tore it apart, except that it was on the left side of the firewall.
Ilya
Old Dec 6, 2006 | 08:03 PM
F6Guy's Avatar
F6Guy
All of the check valves and two speed switches I have seen have been on the drivers side of the truck. Could it be a heater valve?
Old Dec 6, 2006 | 09:00 PM
AXracer's Avatar
AXracer
I think he is describing right and left as he is looking at the firewall rather than the more traditional way of describing the driver's side being left and the passenger's side being right. Or another way of looking at it is like a boat: left and right is relative to an individual's left and right when seated in the vehicle.
1949f1
29
Jul 28, 2016 04:19 AM
lawdawg79
Nov 19, 2015 11:37 PM
shortbed123
25
Sep 30, 2013 10:01 PM
mikeys97ExpEddieB
Sep 10, 2013 05:03 PM
benthere
Feb 13, 2011 05:20 PM
