Sponsored by: Auxito
Injector Pluse rate 2001 F150
Old Oct 27, 2006 | 09:49 AM
Charlie L's Avatar
Charlie L
Thumbs down Injector Pluse rate 2001 F150
I have a probelm that only occurs once in a while: At start up the engine will not idle, finally noted that the injectors were over fueling, no codes or service engine light has come up. If I hold the throttle down for a while it will normally clear out. Any one have this and know the fix? 5.4L engine 80,000 miles on truck.
Old Oct 27, 2006 | 09:58 AM
KevinM's Avatar
KevinM
Your injectors are staying open, I doubt it's because of the pulse rate. It's probably due to dirty injectors. Get a can of SEAFOAM and pour it in the tank at a concentrated rate. Run it and then refuel and see what happens.
SEAFOAM can be bought at Advance Auto stores. If it clears up use an injector cleaner every so often to keep it from happening.
BTW this is not the 2001 forum. Its the 2004 thru 2007 F150 section.
skunktruck
Feb 8, 2009 09:41 AM
jwc8885
4 Cylinder Engines
Mar 27, 2007 08:12 PM
bobsuisun
Aerostar
Jul 30, 2005 05:34 AM
wozxxx86
Nov 11, 2004 09:23 AM
jimmyk57
Apr 27, 2003 06:47 AM
