Sponsored by: Auxito
What to look for
Old Oct 11, 2006 | 08:54 AM
ADub98's Avatar
ADub98
What to look for
I am considering buying a 98 F150 super cab 5.4 with 101k. I know the 98 was near the beginning of production, anything to watch out for on the truck? Any common problems? How do you tell what gear ratio the truck has and if it has the limited slip?
Thanks
AW
Old Oct 11, 2006 | 09:46 AM
xtrford's Avatar
xtrford
Do you have the owners manual? There are metal tabs attached to the pumpkin on the rear diff that have ID codes and compare them to what your manual states, the 5.4l came with the 9.75 inch rear with a minimum 3:55 ratio LS and non-LS.
Old Oct 11, 2006 | 09:53 AM
xtrford's Avatar
xtrford
Another thing to watch for is the plugs on these motors, you are at the recommended mileage to do a plug change and if it is not done correctly you might have a plug spit out on you. They only have a few threads holding them in and if you over tourque them it will cause thread damage due to the aluminum heads...on the other note if they are under torque they might loosen up and eventually come off. There is a thread in this forum for proper proceedure on a plug change, make sure you have a couple of hours handy and factory motorcraft plugs and you should be OK.
Old Oct 11, 2006 | 09:59 AM
ADub98's Avatar
ADub98
No idea if the truck has the owner's manual...or if the tag is still on it. I'm going to try and check it out over lunch
Old Oct 11, 2006 | 12:31 PM
ADub98's Avatar
ADub98
Didn't get a chance to check the gear ratio.
ABS light was on...Ill have to research that. Driver's seat foam seemed to be pretty worn. Seat cover was good, but I sank way down into the seat.
Old Oct 11, 2006 | 07:52 PM
lariat97's Avatar
lariat97
The early build 97 are the ones with the most problems. I doubt the 98 will have many production problems
Old Oct 11, 2006 | 08:59 PM
ADub98's Avatar
ADub98
It seemed like a solid truck. I am heading out of town for a few days, I will be surprised if it is still for sale when I get back. Was going to try and make an offer on it tonight, but I just had too much going on.
1998F150XLT
1997 - 2003 F150
Apr 14, 2013 09:15 PM
00GT
1983 - 2012 Ranger & B-Series
Sep 27, 2007 07:26 AM
BigJohn52
Sep 20, 2005 11:02 AM
brusis
Jan 30, 2004 09:43 AM
