Crane Cam 503901
Old Oct 6, 2006 | 02:16 PM
compaddict's Avatar
compaddict
Crane Cam 503901
Anyone with experience with this camshaft?:
PowerMax Hydraulic Flat Tappet Camshaft Only
Lift: .458''/.487''
Duration: 260°/272°
RPM Range: 1200-4600
TIA,
Vince
Old Oct 6, 2006 | 04:04 PM
compaddict's Avatar
compaddict
One more question!
What's involved in replacing the camshaft (I don't have a service manual yet)?
Again, TIA!
Vince
Old Oct 9, 2006 | 05:37 PM
compaddict's Avatar
compaddict
It looks very easy! One of the few times it's handy not having a cross-flow head I guess.
It doesn't seem that many have much experience with this cam that have chimed in.
After searching it seems many people like the Crane cam I'm looking at so I might do some before and after dyno pulls to share!
Vince
Old Oct 9, 2006 | 06:53 PM
nevrenufhp's Avatar
nevrenufhp
I've heard it's a good all around cam. Changing it isnt hard at all, just remove the V-cover, rocker arms, push rods, tappet cover, lifters, harmonic balancer, timing cover, and it's there...pretty much. For the most power potential, get a Cloyes gear set, they are adjustable from -4,0, and+4 degrees of cam timing. Only cam experience with a 300 I have is a Comp 268 in my nephew's 72. It has a nice choppy idle, but broad power band.
Old Oct 9, 2006 | 07:31 PM
Silver Streak's Avatar
Silver Streak
Don't forget that the radiator and AC condensor have to come out to change it. And the cam gear is a PITA to remove from the cam.
I suspect that not many have chimed in because this cam has been discussed a lot lately in other threads.
Before you pick your cam you need to finish the head work you were talking about in the other thread. You can't make a completely intelligent cam choice without knowing what the head does.
Old Oct 10, 2006 | 12:35 AM
optikal illushun's Avatar
optikal illushun
hehehehe...forgot bout me SS?
Old Oct 10, 2006 | 10:26 AM
compaddict's Avatar
compaddict
SS: I'm not so sure I need to even bother with the head. This truck does nothing but haul my race car around and most of the time it sits at 2200-2500 RPM.
Let me change out the cam, quantify the results and go from there.
Vince
Old Oct 10, 2006 | 06:58 PM
83Van's Avatar
83Van
Have this cam in my [just rebuilt] 300 and it's working great. No real "lope" to the idle quality but it's obviously not stock. Note that this cam has +5 degrees of advance built-in to negate the -4 degrees of retard the factory timing gears give you, so no need to buy the expensive [~$86] adjustable timing set.
If you have the OEM fiber timing gear get the standard Cloyes all metal gear set. Think Autozone has it for just $39. It's worth it to pay a machine shop to press on the cam gear for you. It's beyond a tight fit, even if you do the common trick of heating the gear. The crank gear goes on-off with no problem using a common puller-installer tool, same with the balancer.
Old Oct 10, 2006 | 08:47 PM
compaddict's Avatar
compaddict
Good info!
Do you tow at all?
Vince
F-1
17
May 29, 2019 09:32 AM
BigBlocker0248
Jan 17, 2016 02:46 PM
Charlie Tee
1983 - 2012 Ranger & B-Series
Sep 14, 2015 06:36 PM
pcallycat
15
Feb 14, 2013 11:18 AM
Rubiranch
Nov 18, 2005 12:25 PM
