Modular V10 (6.8l)
how much oil?
Old Sep 24, 2006 | 09:47 PM
apache81's Avatar
apache81
how much oil?
I've been putting 7 quartz of oil in my 03 superduty V10 for awhile,I just relized that the manual says 6 quartz with a filter,any input would be appreciated!
Old Sep 24, 2006 | 10:38 PM
twayneb's Avatar
twayneb
Are you using any oil? Too much oil can cause frothing and not lubricate properly.
Old Sep 24, 2006 | 10:45 PM
apache81's Avatar
apache81
I bought my truck new in 03,it has 15,000 miles now but it does not burn any oil,I change it every 3000.
Old Sep 25, 2006 | 05:37 AM
azdrawdy's Avatar
azdrawdy
Change the oil using six quarts and a filter, then check the dipstick. Five will get you ten that it will be dead in the middle of the hash marks!
Michael
Old Sep 25, 2006 | 06:08 AM
rustyfuryiii's Avatar
rustyfuryiii
Put in the exact amount of oil the manual says to when changing the oil and filter. Run the engine for a few minutes to completely fill the filter. Shut the engine down and let it sit for 15mins or a 1/2 hour on level ground. Then check the dipstick; you can use a razor blade to mark the dipstick where the full mark is. Now you have a reference point for checking the oil level between oil changes.
The engineers that designed and built your engine had Ford put in print the amount of oil you should add when doing an oil change. A dipstick should be used for reference only.
My .02,
RustyFuryIII
Old Sep 25, 2006 | 06:40 AM
azdrawdy's Avatar
azdrawdy
My .02,
RustyFuryIII
And a darn good reference point that dipstick is. Those mere laborers and hackers do a good job when they just slap those things together...Mine's dead center...Unless there's massive tolerance differences in the way the engines are built, six quarts and a filter will show up on mine the same as yours.
apache81's Avatar
apache81
Cool,thanks I'll try that,I guess if I've been overfilling a little but I dont want to see something bad happen,I only use it for towing and it works great,love this truck.
Old Sep 25, 2006 | 07:26 AM
rustyfuryiii
azdrawdy,
On my '06 the manual calls for 7 qts when an oil change with filter is done. After a complete oil change, the oil level is about 1/8" to 3/16ths of an inch above the top line that boxes in the hash marks.
I'm not sure where people are getting the idea that the '06 V10 requires just 6qts of oil after an oil filter and oil are changed. If I'm not mistaken, both the 5.4L and the 6.8L require 7qts.
RustyFuryIII
Old Sep 25, 2006 | 08:52 AM
apache81's Avatar
apache81
I think the manual of a 03' and the 06' recommend a different amount of oil,cause my manual on the 03' says 6 quarts for the 5.4 and 6.8 litre with oil filter,mabye 6 quarts just isnt enough when the filter is changed who knows!
Old Sep 25, 2006 | 08:57 AM
NoMo's Avatar
NoMo
6 quarts in the 1999-2004 models (2-valve heads)
7 quarts in the 2005-2007 models (3-valve heads)
Old Sep 25, 2006 | 09:04 AM
apache81's Avatar
apache81
this is good to know,I just did an oil chage and when I checked the dipstick it was hard to tell exactly where the oil was,my truck sits very high in the front from the 10" lift so that might be another reason,its not sittin level so 7 quarts is saying its full.
Old Sep 25, 2006 | 10:26 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
The 99-04 2-valve V10's take 6 quarts.
The '05-up 3-valve V10's take 7 quarts.
In my case, 6 qts comes up to half way between the low and full marks on the dipstick. I used to fill it with another .5 qts to get it to FULL. If you are getting 7 into it, you are probably checking the oil right after shutting it off? There's a lot of oil in the heads of an OHC motor - especially one as big as the V10. After it drains down, that's the other .5 qts.
Here's my story as to why I stopped adding the extra .5 qts:
I used to get a blue PUFF of smoke from the exhaust, always after starting it for 5-10 seconds, shutting it down, and leaving it until the next day. Start it up, POOF... This a known thing on the V10, lots of people get it, and never have a problem EVER.
However, I tried a little experiment. I started putting only the 6 qts in, and now I hardly EVER get the blue puff.
So, that .5 qts is really doing something. I'm theorizing, but I think there's a lot of oil slung around on initial startup, probably getting more oil up past the rings. Under normal circumstances, this is fine, but with that 10-second-start/shutdown/next-morning-startup routine, I believe the oil that got past the rings is pooling in the cylinder, and the next morning, POOF.
Except for spark-plug longevity (and catalytic converter longevity) I don't think it's a major problem.
However, if Ford says something, there's a reason for it. Keep it at 6 qts, I'd say.
Old Sep 25, 2006 | 10:59 AM
apache81's Avatar
apache81
I dont think running it through this oil change will hurt it huh?I sure hate to try and drain 1 quart of oil out what a mess!
Old Sep 25, 2006 | 11:26 AM
krewat's Avatar
krewat
Don't sweat it!
Oh, and WELCOME to FTE!
Old Sep 25, 2006 | 12:57 PM
bucky440's Avatar
bucky440
I put 6 qt with filter in my 2004 V10. This brings the mark to half way on the dip stick. According to my dealer service department, that is the correct place. If you are using 7 qt, you are deffinately overfilling it!
