Door seals on a '41 1/2ton pick-up
Old Sep 2, 2006 | 01:13 AM
Mich 41's Avatar
Mich 41
Hi there,
just started to put together my '41 bought partially assembled.
According to some source, the only door seal that originally came with the truck would be a bottom seal hold in a retainer?
If that is correct there must have been a lot of draft and noises in the cab.
I understand that the truck does not have been designed for fast cruising, but I guess it can be improved a lot.
Anys suggestions?
Gab.
Old Sep 2, 2006 | 07:39 AM
Fix's Avatar
Fix
My 41 doors only have the bottom seal.
Several after market companies make a foam seal with sticky backing that can be applied to the door seal area. Bob Drake and Obsolete Ford Parts have them. I haven't tried em though, so I can't tell you if they actually work. I think it's probably your best chance at getting the doors to seal without adding a more complicated and modern door seal.
If you try them out, let me know how they work. I might want to install some on my truck.
Old Sep 2, 2006 | 07:48 AM
Fix's Avatar
Fix
I just checked out your gallery.
Looks like we are working on very similar projects. My 46 has the Ranger chassis and a 2.3liter four cylinder (soon to be turbo).
I know a lot of people don't understand my project, but it's nice to see someone else moving away from the standard V8 instalation.
Old Sep 2, 2006 | 11:23 AM
46yblock's Avatar
46yblock
Originally Posted by Mich 41
Hi there,
Anys suggestions?
Gab.
You are correct about there being a bunch of draft and wind noise. It seems like a modern seal should be able to be used. I have an old S-10 that only stays on the farm which I've been meaning to use as a seal donar, to see if it will work.
50trucking
24
May 27, 2025 02:00 PM
Buckt41
New Member Introductions
Mar 4, 2014 07:53 AM
sgrol
6.7L Power Stroke Diesel
Nov 17, 2013 09:29 AM
tinman41
Jun 19, 2008 04:07 PM
Mich 41
1947 and Older Ford Trucks
Oct 3, 2007 08:25 AM
