AC not getting cold in idle and a bit cold when driving
Old Aug 5, 2006 | 09:53 AM
Fershigadig's Avatar
Fershigadig
Question AC not getting cold in idle and a bit cold when driving
Hi everyone.
Last problem. 01 expedition
My AC does not get cold in idle or when Im not moving. In addition know it seems like its not getting very cold when Im driving.
I have added freon (or what ever it is know) and the gauge says that it is full. This was done with a do-it-yourself canister of freon purchased at Autozone. Maybe I didnt put it in right (took forever, not even sure if anything went in)
One thing I have noticed is that the compressor (fly wheel on the engine) clicks on and off all the time. It will go on for about 5 second then shut off and repeats.
Any suggestion would be appreciated.
Old Aug 6, 2006 | 06:51 AM
Modified 99's Avatar
Modified 99
Sounds like a job for an A/C expert. It could be the HI pressure cutout switch.
Old Aug 6, 2006 | 07:03 AM
projectSHO89's Avatar
projectSHO89
Symptoms are of low refrigerant charge.
Steve
Old Aug 6, 2006 | 09:24 PM
Mr.Novice's Avatar
Mr.Novice
Your compressor may be shutting itself off to prevent overheating due to low refrigerant?? If you've given it the ole' college try, it may be time to have a pro look at it.
Old Aug 7, 2006 | 08:09 AM
projectSHO89
Nope. "Short cycling" is usually just low refrigerant level.
The low side-only guages are pretty worthless to determine correct charge, you need to be able to see the high side simultaneously. Kind of like having a brain surgeon with an eyepatch... You wouldn't want that...
Steve
Old Aug 7, 2006 | 08:26 AM
Mr.Novice's Avatar
Mr.Novice
If your can was freezing up on you, you may want to wrap a warm, wet towel around the bottle next time you attempt to add refrigerant.
Be careful not to overcharge though...
Old Aug 14, 2006 | 09:34 PM
virus1200's Avatar
virus1200
mine did the same thing dealer said I had too much freon in system so they let some out it works beautiful now hope this helps
mikentucky
May 24, 2024 07:01 PM
jstihl
27
May 18, 2017 03:38 PM
wulfman
Jun 12, 2011 10:57 PM
Brettddglas
Jun 28, 2004 05:02 PM
yosemite
Jul 11, 2003 09:45 AM
