Leak on Bell Housing
Old Jun 21, 2006 | 07:52 PM
JMullens's Avatar
JMullens
I've noticed a small drip of oil on the bell housing area. No dripping on the gournd yet, but definitely a leak. Anyone else expereincing this?
Old Jun 21, 2006 | 08:07 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
I've seen a lot of posts on this, esp. with a NEW truck. Usually ends up being factory grease melting and just sitting where you're seeing it. Wipe it off...it should disappear within a thousand miles or so. If it gets so bad as it actually drips on the ground, schedule a service call.
Old Jun 21, 2006 | 09:56 PM
Drags's Avatar
Drags
My truck had it. dripped a drop on garage everytime I parked. dealer just put in a rear main seal. we will see if that cures it?.
Old Jun 21, 2006 | 10:27 PM
JMullens's Avatar
JMullens
Thanks for your replies. From the posts I've read this seems to be a fairly common problem with the 6.0
Old Jun 21, 2006 | 10:36 PM
CAFordDude's Avatar
CAFordDude
jmullens,
This was the thread I stared on my "Leak", pictures included. Mine turned out to be nothing. Lots of great feedback though.
https://www.ford-trucks.com/forums/s...d.php?t=495731
Old Jun 22, 2006 | 03:02 AM
JMullens's Avatar
JMullens
Thanks for the pics. That's exactly what mine looks like, but mine is chronic because it keeps coming back. Like I said, nothing crazy, no real drip, just that annoying wet spot and one drop. After reading the posts, I think I'll leave it alone. Sometimes they screw it up more when they try to fix it.
Joe
Old Jun 22, 2006 | 10:12 AM
wassabe's Avatar
wassabe
JMullens, I've had my 06 in the shop twice for the bellhousing leak. First time, tech couldn't find leak so he added tracer dye. I brought it back, as instructed, after 500 miles and they replaced the RMS. Looked good for a few days then oil spot was back. It dosn't leak enough to drip on the ground, but I am going to mention it to the service writer when I bring it in for my first oil change.
Old Jun 22, 2006 | 10:40 AM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
It may or may not be a RMS leak.
Here are a few links with photos on possible causes or "other" causes.
http://www.forddoctorsdts.com/photographs/index3.php
http://www.forddoctorsdts.com/excerpts/index.php
I hope this provides some insight or possible other causes or for you to discuss with your tech about what your specific problem may or may not be.
Bottom line.... it may not be the RMS and they need to investigate further!!! The second link above helps address where one may want to look.
Let us know.
Jeff
