Motorcraft Double Platinum Plugs
Old Jun 8, 2006 | 08:11 PM
Bob Ayers's Avatar
Bob Ayers
I got a new lens for my D70 today, so I thought I would try it out taking pictures of the electrodes on a used DP plug (with 50K miles) comparing it
with a new DP plug:
http://bob-ayers.smugmug.com/gallery/1541882
Old Jun 9, 2006 | 06:34 AM
PSKSAM2's Avatar
PSKSAM2
Nice pics, Bob. A lot better than the ones in the Haynes Manual! I'd say your new lens is working quite well.
It'd be interesting to have a pic of a non-DP 50k used plug to put side by side with those.
-Jim
Old Jun 9, 2006 | 06:55 AM
Bob Ayers's Avatar
Bob Ayers
-Jim
Thanks Jim, here are some more pictures I took with it of a PCB. Let's see if
anybody recognizes what this PCB is out of (people on my FTE mailing list
are excluded on this question) ...ha ha ha ha
http://bob-ayers.smugmug.com/gallery/1541811
Old Jun 9, 2006 | 11:51 PM
jimdandy's Avatar
jimdandy
Smile
It is a power supply for something, what, I have no idea. I will make a SWAG, possibly a computer board. jim d
Old Jun 10, 2006 | 04:47 AM
wendell borror's Avatar
wendell borror
It's an xray of Bob's brain, anybody can see that. If you look close you can see the performance delete resister ha ha !!
Old Jun 10, 2006 | 06:14 PM
Bob Ayers's Avatar
Bob Ayers
You are close Jim!! The Motorola switching regulator is a good hint!! It's actually the DC to DC power supply board for the display in a Ford Ranger radio. I told a fellow FTE member if he sent me his radio (with a dead display) I would fix it for him free, so I could diagnose what causes this common problem. I took pictures, so I can document how to fix the problem. I'll be posting more pictures to my photo site. The radio is fixed!!
Old Jun 10, 2006 | 11:47 PM
Rockledge's Avatar
Rockledge
I gotta admit it, that's a good one. But I suppose there are people who might kid around with me in the same fashion.
Bob, like many other people, I'm interested in seeing the pics of the radio display repair.
Old Jun 11, 2006 | 04:18 AM
Bob Ayers's Avatar
Bob Ayers
I agree, that was a goof one Wendell!!! lol
Joe, here is the URL for my photo site with some pictures (before and after).
There are some pin-thru-hole resistors that run hot, you can see those solder joints. There is also a shield that provides a GND connection from one
end of the board to the other, and you can see those solder joints were cracked also.
Old Jun 12, 2006 | 05:00 PM
Rockledge's Avatar
Rockledge
Bob, looking over those pictures I was wondering if the solder breaks were obvious or if you had to search them out with some sort of magnifying glass? Would a regular solder pencil work once the breaks are identified?
Old Jun 12, 2006 | 05:11 PM
Bob Ayers's Avatar
Bob Ayers
Hi Joe,
The shield tabs were pretty obvious, when I used the shield it to lift the PCB out, one end came up! I have a round fluorescent work light with a big magnifying glass in the middle that helps with inspecting small SMT devices. A low power (25W) soldering pencil works well. Have a good week, and keep in touch Joe!!
Old Jun 14, 2006 | 12:25 PM
Ed21's Avatar
Ed21
Question
So Bob, did you do more than fix the one cracked GND connection on my radio?
A job well done I might add.
Not knowing electronics- were the "pin-thru-hole resistors that run hot" melting the solder connections & about to cause a problem too?
Something tells me that this may not have been a do it yourself repair for me anyway, even with my solder pencil & magnifying glass.
Old Jun 14, 2006 | 04:04 PM
Bob Ayers's Avatar
Bob Ayers
I'm glad your radio worked ok Ed! Yes, I resoldered a lot of joints that looked bad from heat. There is a nak required for soldering SMT (surface mount technology) devices. If you get them too hot, they lift off the board, too cold, and you get a bad solder joint.
Old Jun 17, 2006 | 04:19 PM
Bob Ayers's Avatar
Bob Ayers
After seeing the pictures of the PCB, a friend asked if my new lens would have the resolution to see Lincoln, in the Lincoln memorial, on the back of
a penny. I gave it a try, judge for yourself!!!
http://bob-ayers.smugmug.com/photos/76028196-L.jpg
