bad brake pressure switch
![Cool](images/icons/icon6.gif)
I swapped out my brake switch about two months ago, I had fancy LED bulbs that went bad and had 12VDC on both sides of switch. Anyway installed plain ole bulbs and a new brake switch, I noticied today its not working again. Hooked a meter up to it and it does not pass voltage with brakes applied. I'm wondering are these switches known for this, am I just lucky, or don't buy one from Autozone. Any info would be appreciated.
Don't buy parts at Autozone or any of the cheap parts stores, you get what you pay for. Are you running silicone brake fluid by chance? That stuff seems to mess with the switches. Get a good switch thru NAPA or CarQuest, as long as your using dot 3 fluid. If you have silicone fluid in your system, I hear the Harley-Davidson makes a switch that will be ok with that fluid.
Barry
Barry
From your comments I'm guessing you have the orginal pressure activated switch. When you get tired of the orginal setup switch to a brake light switch that mounts to the brake pedal. I have some pictures in my gallery. It was a fun little project to keep me busy one day. I have almost a hair trigger on those break lights now. My pedal moves about 1/2 inch or less before the lights come on. Someone else has a how to site also, but I did my slightly different since I didn't want to remove all of the original rubber bumper stop.
later
later
later
later
![1st And Best](images/smilies2/fte1.gif)
I just got a new pressure switch at NAPA, works fine we'll see how long it lasts. Not sure why a change to a pedal switch, my lights come on long before stopping. I am running a dual reservoir from a later model Ford and have it inline with the rear brakes, don't know if that makes a difference. Never did really get an answer if these switches are known for going bad other than with silicon.
Thanks
Thanks
Old and Busted
04-02-2014 08:13 PM
tcoates
03-09-2009 03:41 PM
