1971 Ford F-100 Suspension
Old Oct 8, 2002 | 01:56 AM
fordtruckin's Avatar
fordtruckin
Old Oct 9, 2002 | 07:44 AM
F100DREAM's Avatar
F100DREAM
Hello, I was looking under my truck (from the rear) the other day and noticed that the left wheel has more clearance from the frame than the right side.
If the proper rear axle is on the truck, how much space appoximately should there be between the end of the axle (interior hub) and the frame of the truck? And should one side have naturally less clearance than the other side. I will try to depict what I see under the truck here:
| |-------------O----------| |
Frame Wheel Axle Gears Wheel Frame
Yes, the differential in the axle is off center to the right, is that suppose to be? Thanks a lot.
Old Oct 9, 2002 | 09:56 AM
William's Avatar
William
Yup, the entire drive train, engine, transmission and rear differental are off center to the right by a couple of inches. Wierd huh! If you think thats strange take a look at the steering column placement on 61-64 F100s.
William in Atlanta
Old Oct 9, 2002 | 11:42 AM
F100DREAM's Avatar
F100DREAM
Actually, the 1971 steering column is in at an angle also (if that's what you mean). Go figure. It's good to know that I am not just imagining the rear axle off center. Now, is there a way to correct this situation? My tires rub sometime when I have a bed full of wood or drywall?
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Oklahoma Chapter
Apr 11, 2003 10:33 PM
walterdanek
16
Feb 16, 2001 07:56 PM
