302 to 351w swap in a 71 F100
Old Oct 7, 2002 | 10:09 PM
Rd71's Avatar
Rd71
I have 71 F100 thats stock with the exception of PertronixII igniter and matching ingnition coil(302 with C4 tranny).
I am going to pick up what appears to be a 1973 351 windsor tommorow.
The 302 in my truck runs good but is getting tired, 160k.
I plan to rebuild the 351 if rebuildable, if not at least use the heads when the 302 gets rebuild.
I did a search on 302 to 351w swaps, but still not sure what parts would swap from my motor to the 351.
My goal is to get a little more power and to keep it mild and streetable.
The guy with the 351w said it came from a 73 Turino. I don't know for sure.
I appreciate any insight you guys can give.
Old Oct 7, 2002 | 10:46 PM
Mike W's Avatar
Mike W
Put the 351 in. The extra foot-pounds of torque of the 351 really makes a difference.
Old Oct 10, 2002 | 07:17 PM
Supercab's Avatar
Supercab
If this is indeed a 351 Windsor it will be a bolt it swap, accessories and all, just be sure to use the flywheel from the 351.
the only thing you will have to do depending on your present exhaust system is widen it a bit, as 351Ws are wider than 302s.
As a side note back in the early-mid 70s Ford did the einy-meiny-miney -moe on 351s, your friend may have a Cleveland 351, that will also go into your truck, but it will take just a little more doing than the 351W.
Old Oct 10, 2002 | 08:30 PM
Rd71's Avatar
Rd71
Thanks Mike and Supercab.
I brought the motor home last night, it is a 351w. The number on the block is D2AE-6016 and the heads are D00E and look to be rebuildable.
I was not able to pull the oil pan because I don't have an engine stand...yet. The motor is not locked and appears to be stock bore.
There was no flywheel with the motor, but I will check with the seller and see if he has still got it.
What is the differance between the 71 302 flywheel and the flywheel that fits the 351w.
Thanks again Rd71
Old Oct 10, 2002 | 08:39 PM
JTY's Avatar
JTY
Should be the same flywheel.
Old Oct 10, 2002 | 08:41 PM
Mike W's Avatar
Mike W
The balance weight of the flywheel is the same until the mid 80's when the 302 went to a 50 oz. weight. Din't know if the 351 ever changed. You can tell the difference by looking at the two. The 50 oz. is bigger.
Old Oct 10, 2002 | 09:09 PM
Rd71's Avatar
Rd71
Thanks JTY and Supercab
I probabably won't get to far ahead of myself until the block, crank
and heads get a clean bill of health from the machine shop.
The truck has a running 302 in it know, so the 351 will be a winter project.
My goal is to take my time with the 351 rebuild and learn
all I can along the way.
Thanks again guys
Old Oct 12, 2002 | 12:30 AM
72RangerXLT's Avatar
72RangerXLT
I've got a 351W in my 72 and the only thing that I wish that I had for it was a 4bbl carb and intake... and maybe a cam, and some performance heads, and......
The 351W does great! Mine was already in the truck when I bought it so I'm not 100% sure but I think that it came out of a 73 LTD. Got the C4 behind it too. That truck has a lot of torque and pulling power. Sounds like a great swap to me. My dad has an article written by Jack Roush on the interchangabilty of 351W parts to the 289 and 302 block. You can make 300 hp with all stock parts!
Old Oct 12, 2002 | 12:14 PM
gtex's Avatar
gtex
jwingra1971
Feb 3, 2017 09:08 AM
77custom408
Nov 5, 2016 06:40 PM
ss27gogeta
58
Jun 21, 2016 06:10 PM
tonylo
Mar 10, 2012 09:13 PM
jeepsterjayson
Aug 12, 2003 09:29 PM
