Oil pressure
Old Oct 9, 2002 | 06:38 PM
140mph's Avatar
140mph
Oil pressure
i was running starit 40w motor oil in my 70' f250 390
and i was told that was too thick and i also herd it wasn't
i live in minnesota so the climate is a little cooler here
but anyway i just put in 10w 30 and now my oil presure is good
at 2000 to 3000 rpms but when it idols it drops to L is this normal
or is 40w better or is it my oil pump? i would like the opions
of FORD GUYS other than the opion of the macanic who drives a chevy
Old Oct 9, 2002 | 07:08 PM
Mil1ion's Avatar
Mil1ion
Oil pressure
30W is okay in the summer
20W in the winter.
10-30W should be fine though
Do a oil pressure test done with a real gauge though,for peace of mind!
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Oct 9, 2002 | 08:11 PM
Mike W's Avatar
Mike W
Oil pressure
10 pounds per 1000 rpm is fine.
Old Oct 10, 2002 | 06:08 AM
jowilker's Avatar
jowilker
Oil pressure
I agree with the above posts 10-30 oil & 10 lbs per 1000 pressure.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member 0004 since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Oct 10, 2002 | 06:40 PM
71cc's Avatar
71cc
Oil pressure
Try pouring out a quart of straight 40w when it is 20 degrees and you will see why it cannot get into the bearings to do its job.Here in Texas I only use 10w40 in the 100 degree summer months.
Old Oct 10, 2002 | 09:56 PM
mlf72f250's Avatar
mlf72f250
Oil pressure
[updated:LAST EDITED ON 10-Oct-02 AT 10:58 PM (EST)]If you want reliable cranking and starting for those Minnesota winters, then 5W-30 is your best bet. Better yet, Mobil 1 5W-30. On those -20F mornings, it will make the difference. 20W-50 won't even crank. But on those hot summer drives, the 20W-50 leaks less. That has been my experience.
--Matt
1972 F250 Custom Sport Camper Special 4x2 360 2v C6 3.73
Soon to have a 104" wheelbase as part of a Broncification project
My FTE Website -- http://www.clubfte.com/users/mlf72f250/index.html
My Galleries -- https://www.ford-trucks.com/user_gallery/displaygallery.php?userid=1108
Old Oct 11, 2002 | 04:13 AM
BrettCox's Avatar
BrettCox
Oil pressure
You need the thinner oil where you are for sure! I used 15w40 in Yuma Az but it got to 125 degrees there there on a good day. From what I know 5w30 means the oil acts like 5 weight in the winter and 30 in the summer? If you put that thick oil in your engine it be like cake batter in the winter and you motor would have a dry start wiping out all high friction areas.
Old Oct 13, 2002 | 01:35 AM
gonefishin's Avatar
gonefishin
Post Oil pressure
Old Oct 14, 2002 | 05:04 PM
140mph's Avatar
140mph
Oil pressure
alright now that i know my oil selection is good then
why is my pressure so low after switching them?
now i can hear the valves start ticking after idol
for 5 or 10 minutes, i do know that ticking in not a good
sign?
Old Oct 14, 2002 | 08:44 PM
mlf72f250's Avatar
mlf72f250
Oil pressure
It might be a sign of a worn oil pump or worn rod and main bearings.
We had a beige '66 with the inline 240 6 cyl that had low oil pressure and made those lifter noises at low rpms. Eventually it made rod noises. We probably should have replaced the pump and bearings before it got that bad. We gave it to a friend who made it into a trailer. It's still probably hauling junk around Austin.
--Matt
Old Oct 14, 2002 | 10:07 PM
big block power's Avatar
big block power
Oil pressure
Ticking could be lifters getting sticky
also, try a cold compresion test,then
try the comp while its hot. compare the
readings and the ones with funny readings while cold
probaly have some sticking action in the
valves or lifters.
Fe power
samahi72
Jan 12, 2016 11:03 PM
bryanlindborg600
27
Sep 30, 2013 06:52 PM
mgd4me
Dec 17, 2011 08:55 AM
Johnlwlr
Feb 11, 2011 06:09 AM
bronco_94
1978 - 1996 Big Bronco
Nov 8, 2004 02:48 PM
