ford 9 inch rear end
Old Mar 22, 2006 | 03:47 PM
khorse's Avatar
khorse
i recently stumbled upon three Ford 9 inch rear ends and was wandering how much $ i should ask for them. any advice?
Old Mar 22, 2006 | 04:24 PM
Jmudder79's Avatar
Jmudder79
What ratio are they? Any kind of locker, limited slip?
Old Mar 22, 2006 | 07:14 PM
RTM's Avatar
RTM
Also what spline and what are they from? Do you need them or are you looking to turn a profit? If profit is what your after then wouldn't pay more than $50 a piece. That's all I can get out of a 9 inch with 3.00 or down open gear sets. A 3.50 set up will bring more and a 4.11 even more. Add a trac loc and the price just jumped $100. If you get a 28 spline trac loc it will sell much quicker than a 31 spline unit.
Old Mar 22, 2006 | 11:03 PM
rebocardo's Avatar
rebocardo
Any complete axle, drum to drum, around here is worth $100-$135, even DRW. Some of the "undesirable" axles such as 3.00 9 inches and 7.5 rears are even less, maybe $50.00.
Old Mar 23, 2006 | 02:49 PM
khorse's Avatar
khorse
how can i tell what the gear ratio is? or, if it limited slip, etc.?
Old Mar 23, 2006 | 02:59 PM
1975Ford's Avatar
1975Ford
Look for this tag mounted on the third member, https://www.ford-trucks.com/user_gal...=94739&width=0, will probably need to scrap off some greas to read the gear ration number. If your truck is 4x4, make sure you match up the front gear ratio with your new 9" rear end.
no more than $150. average price $125.oo.
Old Mar 23, 2006 | 03:40 PM
khorse's Avatar
khorse
hate to ask this but, "what is the third member?"
Old Mar 23, 2006 | 03:43 PM
1975Ford's Avatar
1975Ford
The third member (also known as "aka" carrier housing) and is the part which hold the yoke, pinon gear, ring gear and bearings. https://www.ford-trucks.com/user_gal...=94740&width=0 The rear tag is mounted to one of the ten nuts which hold the third member in place.
----buck----
Old Mar 23, 2006 | 03:57 PM
khorse's Avatar
khorse
neither one of mine have a tag on any of the ten bolts. previous owner must have taken them off or something.
Old Mar 23, 2006 | 04:00 PM
1975Ford's Avatar
1975Ford
try this useful post in determining your gear ratio if needed https://www.ford-trucks.com/forums/s...81&postcount=6
-----buck----
Old Mar 23, 2006 | 04:07 PM
khorse's Avatar
khorse
thanks for the post, Buck, but the two rear ends that i am talking about are in the bed of my truck. don't think the rope/duct tape trick will work.
Old Mar 23, 2006 | 04:21 PM
1975Ford's Avatar
1975Ford
Lift the axle housing and place a block under to hold up alxe. mark yoke with paint and mark drum. Have an assistance count how many time the drum turns and count how many times the yoke has turned. Go 2 complete revs with the yoke and count how many times the axle / drum rotated. divide number of times yoke turned into number of revs the axle drum rotated to solve for the gear ratio.
--Buck--
Detector2
Jun 28, 2013 03:06 PM
David LaPell
Sep 21, 2010 06:22 AM
bigblockford_390
Nov 22, 2007 05:45 PM
BubbasRacing
Sep 3, 2002 06:22 PM
