Offroad & 4x4
Rear suspension setup for 78 f150
Old Mar 20, 2006 | 11:07 AM
KJKozak2's Avatar
KJKozak2
I was talking to a friend yesterday and he was telling me about a rear suspension setup he saw on some EBs that sounded interesting. The rear leaf spring shackle was not bolted to the frame, but to some sort of arm that pivoted in the center of the frame. On flat ground, it sits in it's normal position. But when the truck twists, the shackle drops away from the frame allowing more flex.
The basic principal is similar to unbolting the top of a coil spring and allowing it to drop when flexing (using a coil bucket of course).
Has anyone ever seen or done this? Any thoughts?
TIA.
Kevin K.
Old Mar 20, 2006 | 11:29 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
sounds like a "buggy leaf" type setup
it produces more flex, but i dont think its useful flex, the usuaully end up causing mroe problems than they are worth
Old Mar 20, 2006 | 01:11 PM
SoArkSI's Avatar
SoArkSI
unless i am missing somthing, it sounds like a revolver shackle.
Old Mar 20, 2006 | 01:27 PM
KJKozak2's Avatar
KJKozak2
Does a revolver shackle bottom out on the frame so only the bottom piece flexes under normal suspension travel?
I found a few pix on the web and that's the way is appears to me. If so, that's a much simpler way to achieve the same thing.
Are there any drawbacks to a revolver shackle on a full size truck?
Kevin K.
Old Mar 20, 2006 | 03:47 PM
KubotaOrange76
they give you crappy axle wrap, make it very unstable on hills and can bend leaves....they arent worth it because they are useless flex
it sounds like you are talking about a "buggy leaf" type setup same thing except the shackle is normal but attachted tothe end of a leafspring thats attached to the frame, or the shackl eis just attacthed to a bar that rests against the frame and lets the spring move down when the axle droops
Old Mar 20, 2006 | 05:21 PM
fordtruggy's Avatar
fordtruggy
A revolver shackel can be a verry good shackel in some situations.In other instances they can unload at the wrong time and cause you to tip over.
Old Mar 20, 2006 | 06:52 PM
KubotaOrange76
ive never seen a situation where the good outweighs the bad....theres a reason you dont see them on anything in competitions
Old Mar 20, 2006 | 10:12 PM
Flareside94's Avatar
Flareside94
KO, they do sometimes work right. As said though, they want to unload when you're sidehilling which flops you..or actually rolls you down a big enough hill.
I know what you saw, was it a ranger over on Pirate? Like 10' long shackles - not a good setup. You can do better with coilovers or something. Safer.
Old Mar 21, 2006 | 12:23 AM
mustange70's Avatar
mustange70
He's talking about what i seen called in a recent petersons mag a zig zag shackle or somehting like that, i'll dig around for the mag tomorrow and post up, but essentiall the rear of the leaf spring isn't solidly attached to the frame.
Old Mar 21, 2006 | 12:31 AM
74fordtruck's Avatar
74fordtruck
Okay, i'm not really seeing the usefulness of the revolver anyways. If it unbuckles to let the wheel reach the ground, doesnt that mean that the only weight it has on it for traction is from the tire and half the axle? Doesnt quite seem useful to me.
Old Mar 21, 2006 | 12:34 AM
KubotaOrange76
exactly....
Old Mar 21, 2006 | 12:37 AM
74fordtruck
Cool, then count me in
Old Mar 21, 2006 | 07:29 AM
KJKozak2's Avatar
KJKozak2
Thanks guys.
Now I know why I haven't seen a lot of these. If they were any good, there'd be a lot more around.
Kevin K.
Old Mar 21, 2006 | 08:20 AM
fishmanndotcom's Avatar
fishmanndotcom
there must be some truth to it if it is beiong mass produced!
http://www.rubiconusa.com/store/prod...oductnum=NDMZZ
-cutts-
Old Mar 21, 2006 | 10:05 AM
KubotaOrange76
ive never seen anything like that before....looks good except i can see the back doing some serious lifting under power due to axle wrap
Ford79
Offroad & 4x4
46
Nov 18, 2015 05:14 AM
OldWoodsDiesel
Oct 22, 2012 07:45 AM
timmygyu
1978 - 1996 Big Bronco
Jun 24, 2012 07:33 PM
quaallen
Offroad & 4x4
Feb 13, 2011 05:17 PM
tonydlt
Mar 15, 2007 07:45 PM
