Rear suspension setup for 78 f150
I was talking to a friend yesterday and he was telling me about a rear suspension setup he saw on some EBs that sounded interesting. The rear leaf spring shackle was not bolted to the frame, but to some sort of arm that pivoted in the center of the frame. On flat ground, it sits in it's normal position. But when the truck twists, the shackle drops away from the frame allowing more flex.
The basic principal is similar to unbolting the top of a coil spring and allowing it to drop when flexing (using a coil bucket of course).
Has anyone ever seen or done this? Any thoughts?
TIA.
Kevin K.
TIA.
Kevin K.
Does a revolver shackle bottom out on the frame so only the bottom piece flexes under normal suspension travel?
I found a few pix on the web and that's the way is appears to me. If so, that's a much simpler way to achieve the same thing.
Are there any drawbacks to a revolver shackle on a full size truck?
Kevin K.
Kevin K.
they give you crappy axle wrap, make it very unstable on hills and can bend leaves....they arent worth it because they are useless flex
it sounds like you are talking about a "buggy leaf" type setup same thing except the shackle is normal but attachted tothe end of a leafspring thats attached to the frame, or the shackl eis just attacthed to a bar that rests against the frame and lets the spring move down when the axle droops
KO, they do sometimes work right. As said though, they want to unload when you're sidehilling which flops you..or actually rolls you down a big enough hill.
I know what you saw, was it a ranger over on Pirate? Like 10' long shackles - not a good setup. You can do better with coilovers or something. Safer.
there must be some truth to it if it is beiong mass produced!
http://www.rubiconusa.com/store/prod...oductnum=NDMZZ
-cutts-
-cutts-
OldWoodsDiesel
10-22-2012 07:45 AM
