Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Easy to make oil filter wrench
Old Jun 8, 2002 | 10:46 AM
HotWhlz85's Avatar
HotWhlz85
[updated:LAST EDITED ON 08-Jun-02 AT 11:51 AM (EST)]After fighting with store bought wrenches that didn't last or wouldnt grip like they promised, I made my own. I used a piece of flat 1/4 inch steel 8 inches long by 1 1/2 inches wide. Using a bench grinder, I ground one corner off to make a radius to allow the wrench to tighten and grip the filter. Then I drilled a hole at either end of the radius. Next I took a 12 inch length of bicycle chain and attached it to the steel handle through the holes I just drilled. And it's done. The chain is flexible enough to allow me to get into some of the tightest places. Total cost: it was stuff I had lying around so all it cost was my time.
Here's a rough drawing of what the steps are:
http://www.geocities.com/hotwhlz85/images/filterwrench.gif
Ron
Old Jun 8, 2002 | 01:53 PM
HotWhlz85's Avatar
HotWhlz85
[updated:LAST EDITED ON 08-Jun-02 AT 03:05 PM (EST)]&%$#@)*&^ HTML!!!!!!
Never does do like I want it to. Guess I need the Greywolf "HTML for dummies" course.
If you wanna see this pic cut and paste this URL:
http://www.geocities.com/hotwhlz85/filterwrench.html
Sorry, it's just been that kinda day.
Old Jun 8, 2002 | 11:53 PM
wolfmanagh's Avatar
wolfmanagh
hotwhlz85,
I had the same problem a while back and I figured that geocities dosn't support that little feature. You could use a link described in the "html reference". [link:www.geocities.com/hotwhlz85/filterwrench|www.geocities.com/hotwhlz85/filterwrench]
Old Jun 9, 2002 | 12:29 AM
TKONO's Avatar
TKONO
I have found chain Vice-Grips to be very effective for that also. Not as cheap, but I'm lazy.
Old Jun 10, 2002 | 08:11 AM
76supercab's Avatar
76supercab
I just use my dog's choke chain collar.
Old Jun 19, 2002 | 10:32 AM
ringkong's Avatar
ringkong
Or you could pound a screw driver into the old filter and turn it with that.... cheap and quick..
Old Jun 19, 2002 | 01:39 PM
Rosati's Avatar
Rosati
I usually slam a small screwdriver in the bottom to drain the oil into the empty pan first, then drain the oil from the pan, then take a screwdriver and poke it through the side and twist it off. Keeps the side of the engine clean and the frame clean.
Old Jul 28, 2002 | 11:21 AM
76F100351W's Avatar
76F100351W
I just get FRAM Easy Grip oil filters, been fairly easy since!
Old Jul 28, 2002 | 09:23 PM
rebocardo's Avatar
rebocardo
I use to work in a lube bay and found big channel lock/water pump plyers and a three prong claw thing I got from northerntool.com to be the best and quickest things. Except on GM cars where they mount them on the right side of the car inside the unibody frame rail, then the best thing is a sawz-all ;->
Old Jul 29, 2002 | 02:48 PM
TorqueKing's Avatar
TorqueKing
FRAM FILTERS????? ARGH!!!!!!!!!!!!!!!
please, please go to the "oil and lubrication" forum, and find a link to the oil filter study. I can't stand to see Fords on the side of the road, and you're doing your best to get it there with a Fram. I have used 1 Fram filter ever in my life, and I yanked it and did another oil change because the engine ran worse and the oil was filthy almost immediately. I think a Motorcraft or any other quality filter is better after 10,000 miles than a Fram after 800 miles. The guts are made of cardboard, and they fall off or disentigrate within a month, or 800 miles. Go buy a filter wrench, they cost no more than $10, get any of the fine filters available (some are even cheaper than that orange box foolishness), and they'll save the life of your engine. Although it is a topic for another forum, I'd greatly encourage all of you to be warned about the Fram scam, it's a disaster waiting to happen for good, hard working people like yourselves who assume that every American company is as dedicated to quality as you are. Possibly an eggageration, but from what I've read, and my experience with their products, it's a true corporate scam, and even Fram engineers have candidly admitted that they've scarificed quality to make more money, since their reputation has been established to many people. TK
'77 F100, 302 (the aftermarket Prodigy), C4
Cadet Second Lieutenant John F. Daly III
South Carolina Corps of Cadets, The Citadel
The TorqueKing
Old Sep 2, 2002 | 08:44 PM
Brian_Mc's Avatar
Brian_Mc
[updated:LAST EDITED ON 02-Sep-02 AT 09:46 PM (EST)]Forgive me if this is obvious, I just found this forum, but...
I tried to find the "oil and lubrication" forum, but couldn't. Could you help me out?
Thanks in advance...
Nevermind. I just used that new fangled thing called a scroll bar. That and pulling my head out of my butt made all the difference!
Old Sep 2, 2002 | 08:51 PM
TheWiz427's Avatar
TheWiz427
At the top or bottom of this page click on conferences and then scroll down the page to the oil and lubrication forum and click your there.
Wiz
"Fear leads to anger;anger leads to hate;hate leads to suffering"........Yoda
http://www.clubfte.com/users/thewiz427/index.html
Old Sep 2, 2002 | 10:25 PM
BigDeezil58's Avatar
BigDeezil58
I've ruined a few good leather belts when I have had to get clogged fuel filters off in 10°F. weather! Couldn't get in the tool box...it was frozen shut! Nothing like changing filters, and trying to hold your pants up on the side of the road!
So, nothing beats a homemade specialty tool...even if you have to use it with just your shorts on!
Old Sep 5, 2002 | 01:34 AM
pcmenten's Avatar
pcmenten
anthonym92
15
Mar 19, 2017 10:56 PM
ubereal2
2009 - 2014 F150
Feb 14, 2017 09:35 PM
nzirbel
Aug 9, 2016 06:31 AM
Mr. Obvious
Modular V10 (6.8l)
Mar 31, 2016 10:06 AM
akamacgyver
Nov 13, 2015 05:49 PM
