Steps to replace Radius Arm Bushings....help
Old Mar 4, 2017 | 06:59 PM
anthonym92's Avatar
anthonym92
So I've found the problem as to why my tires bow out at the bottom causing inner tire wear. My radius arm bushings are shot. Anyways I believe I've done enough research thanks to you guys and your posts. I want to make sure I have the steps down that I need. This is for a 88 F150 4x4.
Raise one side (only one stand) and secure frame on stand. Place jack under axle and raise it to remove tire. Unbolt shocks and spring. Unbolt 1 1/8 inch nut on radius arm. Lower axle and it should come out, use a steel bar to pull axle forward if needed. Replace bushings. Install is reverse. Am I missing anything?
Old Mar 4, 2017 | 07:25 PM
f1504x4driver's Avatar
f1504x4driver
Proud Pirate
Have a come-along handy. Will make it easier to reinstall the radius arms and tighten the nuts. Virtually impossible without.
Old Mar 4, 2017 | 07:29 PM
anthonym92's Avatar
anthonym92
My buddy has a 2 ton one. I'll ask to borrow it. Other than that is there anything else that needs to be done before lowering the axle?
Old Mar 4, 2017 | 07:48 PM
garthneddy's Avatar
garthneddy
I never had to lower my axles. Heck, all four tires were still bearing the trucks weight. Just unbolt the radius arm and pull it forward with a come along to remove and install the bushings, then bolt it back together.
Old Mar 4, 2017 | 07:55 PM
anthonym92's Avatar
anthonym92
I was wondering if I could do that haha. I almost forgot, I have to take the front driveshaft off too right? Sorry for the questions, I just want to make this as easy and least time consuming as possible
Old Mar 4, 2017 | 08:05 PM
garthneddy's Avatar
garthneddy
I didn't with mine, might need to pull the bumper though. My old bald 31s got into it right when I had enough clearance to remove the bushings.
Old Mar 17, 2017 | 07:30 PM
Blind Driver's Avatar
Blind Driver
Grind off the rivets off the bracket, then replace with bolts.
Old Mar 17, 2017 | 07:47 PM
GoinBoarding's Avatar
GoinBoarding
I think you're missing that the radius arm bushings probably aren't the cause of bad camber. Never a bad idea to keep them fresh, but I'd take a close look at the axle pivot bushings. Those are a more likely suspect for poor camber.
Old Mar 17, 2017 | 08:21 PM
My4Fordtrucks's Avatar
My4Fordtrucks
I second this. Another possibility would be worn out parts and/or weak springs.
When I do radius arm bushings I unbolt the lower shock mount(s), remove the coil spring, loosen the radius arm upper stud and lower bolt and then the radius arm nut/assembly. Loosening the front of the radius arm allows you to swing the arm to help get it in and out of the bracket. That is the method I was taught when I worked at the Ford dealer but as mentioned there are several ways to skin this cat.
Old Mar 19, 2017 | 08:23 PM
anthonym92's Avatar
anthonym92
After replacing the radius arm bushings (which wasn't hard at all) the wandering while driving has cleared up completely. All bushings were shot. Anyways I noticed afterwards that my tires bow out still however I noticed while putting everything together that it seems to be from toe out. My tires look like \ / slightly if you look from about but it seems to be enough to indicate an alignment issue. Would toe out even a little be enough to give the look of \ / when looking from above and / \ from the front? And would it cause the inner tire wear I'm having?
Old Mar 19, 2017 | 08:31 PM
yardbird's Avatar
yardbird
Pivot arm bushings are probably worn out. Worn out bushings will cause negative camber and a toe in condition at the same time.
Old Mar 19, 2017 | 09:37 PM
anthonym92's Avatar
anthonym92
How hard is it to do the pivot arm bushings and maybe a run down on how to do them?
Old Mar 19, 2017 | 09:57 PM
LeoJr's Avatar
LeoJr
It may be of very little help, but my 250 with its TTB independant front end, would always get bow legged when it was reversed.
Old Mar 19, 2017 | 10:09 PM
anthonym92's Avatar
anthonym92
Yeah I had heard about that but this is after my truck has been driven a mile and I park it having never reversed it. I checked out the ball joints today using the 12 and 6 o'clock method after lifting each end and I also used a rod under each tire to check the ball joints. There is no play and they look pretty darn good. No popping sound either. It has new springs, tie rods and drag link, deleted the sway bar so no bushings for that and did new radius arm bushings today. Only thing I can think of is front quad springs (they are shot as well) and the axle pivot bushings and a bad toe out alignment. Anything else to look at?
Old Mar 19, 2017 | 10:20 PM
GoinBoarding
That's a good point Leo. Make sure you're checking camber only after the truck has rolled forward.
Camber has less effect on tire wear than toe. So make sure toe is set with just a touch of toe in. Toe out causes wandering. If camber is off when the truck has rolled forward, a few things could be the cause. Ball joints if really worn. Axle pivot bushings if worn. And coil springs if old & sacked out. Inspect the pivot bushings best you can. Pushing up on the axle near the bushings with a jack and watching for how far the beam moves in the mount can give you an idea of how far they're compressed.
The last time I replaced mine I dropped the whole front axle, and replaced radius arm bushings at the same time (and sway bar bushings, and axle shaft U joints). I used a ball joint press to remove & install the bushings in the beams. The first time I did it I left the axle in the truck and struggled to make enough room (left the axle shafts in place, may be where I went wrong). I know it can be done both ways, plenty of guys leave the axle in the truck. I'll drop the axle again next time I need to do them though.
