240 to 300 conversion
Old Mar 2, 2006 | 08:44 AM
Gatsby's Avatar
Gatsby
Question 240 to 300 conversion
I was parking at work the other morning when I heard a most disturbing sound coming from under the hood of my 1966 F-100. My first thought was that the sound was coming from the valve train area (needless to say, I shut the engine off immediately when I heard the calamity). I had the truck towed to a shop and a mechanic looked under the valve cover--all was well. The mechanic thinks I have either, or possibly both, a torn piston skirt or a wrist pin problem. With that scenario, I expect to have cylinder damage as well. I have been looking for a used 240 block (same engine that's currently in the truck) and have not been able to find one. I have found plenty of 300 blocks. Are my 240 parts (crank and bearings, rods, pistons, cam, pushrods, distributor, etc.) completely interchangable with the 300 block? Also, does anyone know of a good detailed manual for working on a 240/300 (tearing the motor down and putting it back together)? I have never been into an engine before so this will be a first for me. Any help you can offer on these issuess is greatly appreciated!
Old Mar 3, 2006 | 03:02 AM
Col Flashman's Avatar
Col Flashman
The 300c.i.er is a Bored & Stroked 240c.i.er, so a lot of the internals wont fit as you'd wish them to.
The '66, 240/300 I-6 Ford Shop Manual has all the intel you need on tearing down & putting back together either of those engines.
Old Mar 3, 2006 | 08:46 AM
Gatsby's Avatar
Gatsby
I am unable to find the manuals specifically for the 240/300 I-6. Many sites carry the Ford Shop manuals for the V-8's or chassis, maintenance, and/or electrical manuals. Do you know of a vendor that carries the Ford Shop manual specifically for the 240/300 I-6 engines? thanks for your help.
Old Mar 3, 2006 | 03:14 PM
Col Flashman
I just did a search on e-Bay & found this,
http://cgi.ebay.com/FORD-240-300-361...QQcmdZViewItem
Contact this Seller about a Shop Manual,
http://cgi.ebay.com/ebaymotors/Ford-...spagenameZWDVW
Old Mar 4, 2006 | 08:08 PM
stresssolutions's Avatar
stresssolutions
I've got a 240 in a 66 custom 500 4 door sedan, been sitting in a field for 13 years though, with nothing done to it. Sad, I had overhauled it just a few years earlier, but it was not running right when parked. Coil or condenser or soemthing.
A 300 will bolt in, in place of the 240...bellhousing and motormounts are the same.
Good luck
Old Mar 4, 2006 | 10:20 PM
ptmilan's Avatar
ptmilan
The 240 and 300 use the same block. Only the internals are different (crankshaft, rods, etc). The 300 is a direct bolt in replacement, so that would be the best choice given the power increase. You might have to change to a bigger clutch. Some 240s had a smaller clutch than any of the 300s. A 300 could be converted to a 240, but for the same money you can have 60 more cubic inches.
Old Mar 5, 2006 | 01:09 AM
Bdox's Avatar
Bdox
Right. Just install a 300 short block with your top end.
Old Mar 8, 2006 | 03:34 PM
Gatsby's Avatar
Gatsby
Thanks for everyone's comments. I have found the appropriate shop manuals and will be pulling the engine in a couple of weeks.
trozei
92
Aug 19, 2022 05:08 PM
gear_grinder
38
Dec 24, 2020 02:12 PM
trozei
40
Sep 12, 2020 09:22 PM
BaronVonAutomatc
211
Mar 21, 2018 12:47 PM
cdherman
May 5, 2004 08:17 AM
