Mass Air EFI Conversion for 390 FE
Old Feb 20, 2006 | 05:32 PM
workingdog's Avatar
workingdog
The search is not working right now and I didn't see this discussed in the last couple of month's postings so I'll give it a go.
Can I take my 1968 F250 with mildly built 390 to a Mass Air EEC VI? IF so what year and truck would I look to get one out of?
Are there fuel injected throttle bodies in standard 4 barrel size that I can mount on my Edelbrock performer and that will work with an EEC VI box?
What kind of distributor do I need to run?
Sorry this questions are so basic, but I've been looking in to fuel injecting this truck for a while and only recently realized that all modern Ford trucks are Mass Air injected. It seems like it would have to be a lot cheaper to use something like TwEECer than pay a lot of money for an aftermarket EFI setup like TEC3r or Mass-Flo. Why is it that almost all the aftermarket fuel injection systems are speed density?
Peter
Old Feb 20, 2006 | 08:18 PM
EPNCSU2006's Avatar
EPNCSU2006
Have you seen this?:
http://www.mass-floefi.com/
Old Feb 20, 2006 | 08:46 PM
workingdog's Avatar
workingdog
Yes, for the FE it's almost $4,000. Why is it so much money?
Peter
Old Feb 20, 2006 | 10:06 PM
Ford_Six's Avatar
Ford_Six
The FE series never had EFI from the factory, so you will have to modify an intake to accept the injectors. I only know of two or three vehicles that came with throttle body injection and mass-air, and all those systems are too small to run a v8. I'm not saying it can't be done, but you'll be below the level of a well-tuned mulitport speed density system.
Old Feb 22, 2006 | 11:36 PM
jopey's Avatar
jopey
I do not know what dizzy the fe's used, but if there is any TFI dizzy which can be dropped in there, or even modify your dizzy to use the guts from a TFI dizzy. having the injector bungs put into a intake is not that expensive. I would say I am around 2k into putting EFI on my 400, and that is including the tweecer to tune it.
Old Feb 23, 2006 | 04:16 PM
workingdog's Avatar
workingdog
I have a victor ready to be modified for multi-port - I just figured throttle body would be an easier first step. I have a MSD distributor in there, but the Mas-Flo kit comes with a Mallory - Is that what I need? Can I do fuel only with an EEC VI?
Peter
Old Feb 23, 2006 | 09:50 PM
Ford_Six's Avatar
Ford_Six
I don't think it will work as a stand alone fuel controller. I do know that you can modify a Megasquirt controller to use a mass air sensor, though. I think the info for that can be found in the Yahoo discussion group for Megasquirt.
Old Feb 23, 2006 | 09:56 PM
jopey's Avatar
jopey
the dizzy fires the ignition as well as tells the ECM what injectors to fire. There might be a few hacks for other dizzys to work, but researching that will be fun.
CaptainJack_7
Feb 23, 2016 07:53 AM
dan15000
Jan 29, 2014 08:20 AM
jarod17
Testing.....
Jun 28, 2011 10:57 PM
oldproudvet
Dec 3, 2009 06:10 AM
BigBlockF-250
Oct 5, 2004 09:59 AM
