Hello again, I am going to change the oil on my Explorer this weekend with Royal Purple of course and would like opinions on oil filters. Currently I think the best one I can find easily is the K&N brand which I have used. I also heard good things and have used the Mobil 1 Filter.
I am sure there are other filters out there that are great as well. On the other note I read that Fram filters suck as do champion and quaker state.
Where'd that thread go that was just up about the Motorcraft filters? It's on FTE somewhere, and if you search Motorcraft, I'm sure it'll be one of the first ones to come up.
In a nutshell, based on what was said in there, go Motorcraft.
-for the real& gruesome lowdown on America's fav oil filter :
Engine Oil Filter Study
by Russ W. Knize
One weekend I set out to every auto parts store in my area and bought every brand of oil filter I could find. I chose to get the filter for the early Ford 5.0L V8 engine. The reason is that this is a popular filter, it is large so that I can unveil any fake miniature internal components, and it fits on most 2.2L and 2.5L engines. Design-wise it is fully compatible with our oil systems and is an excellent replacement for the pathetic filter that was designed for our engines. I was able to find 20 different filters spanning several brand names
'Disassembly and Measurements...
Basically, I cut open each filter on a lathe and took measurements of many of their attributes. Simply cutting them open revealed some very interesting (and disturbing) information.
My Friend Works For A Aircraft Mfg. And They Did An Independent Test And The Baldwins Came Out The Best By Far And The Frams They Advised Not To Use On Anything You Valued.they Now Use All Baldwin On Everything
