302 oil leak
Old Jan 25, 2006 | 04:58 PM
Young_unn's Avatar
Young_unn
302 oil leak
i have a 73 econoline 200 ford van, it used the same 302 as the f-100/150's used in the 70's
i have an oil leak coming fromt he top of then engine, all i can say so far is that it leaks alot of oil and that i havent been able to take the time to look at it,
is there any oil problems with the early 70's 302?
Old Jan 25, 2006 | 06:03 PM
Customcab's Avatar
Customcab
I got a newly built 302 with no problem; an prior to rebuild it only shown oil around valve covers gaskets.
I recommend you post this thread under the engine performance section under the 302 post. Those folks are the guru's for engine problems.
Mitch
Old Jan 27, 2006 | 09:46 AM
daveengelson's Avatar
daveengelson
Installed rebuilt 70 Torino 302 in 65 F100 about 3 years ago. After while finding excess oil in engine compartment. Went thru and re-torqued, oh what a difference. May want to check V-cover gaskets they are notorious for leaking. If engine has lot of miles then usally find engine leaking from every place imaginable. Suggest run a search and narrow field to 302 engine forum 'oil leak', or something simular. Believe in around mid 70's, at least in Ca., the 302 heads were changed for smog purposes not sure if resulted in lot of excess 'blow by' in engine compartment.
dave
Old Jan 27, 2006 | 12:50 PM
jsutton's Avatar
jsutton
These are also notorious for leaking at the front of the intake manifold! I have always heard never use the cork gasket that comes with the set for the front or the back. You should run a thick bead of rtv across there and make that the gasket. Just another spot to check for a leak.
Jason
77 f100
Old Jan 28, 2006 | 10:05 AM
daveengelson
Oh ya, the darn intake manifold gasket. Experience simular problem only it concerned locating a water leak. Posted topic in the 'engine forum' 302 section. Majority of the responses directed me to the intake manifold gasket, in particular as Jason indicated, the end pieces. There seemed to be couple schools of thought from whether to use gasket, sealant, or combination of both. Went with quality gasket and sealant which solved the problem. Torque value and tighening sequence is important.
dave
Old Jan 29, 2006 | 02:15 PM
Young_unn's Avatar
Young_unn
mine looks liek its coming fromt he back of the left valve cover, ill clean it off and take a look today.
Old Apr 27, 2006 | 12:28 AM
ceverest's Avatar
ceverest
im leaking oil from every gasket on my 302 plus an oil pan leak... I think I lose about 2 quarts a week. I think I'm going to do a full gasket and oil pan replacement this summer.
schnide
Oct 23, 2015 10:39 AM
Ki-Adi-Mundi
Jan 5, 2015 10:24 PM
Missin'A Gear
Jul 26, 2014 01:12 PM
roy123
Aug 18, 2013 06:11 PM
