Removing cylinder head bollt stub ???? shavings???
Old Jan 14, 2006 | 11:17 AM
Narwhal's Avatar
Narwhal
I removed the broken stub of the cylinder head bolt on my 239 V8 flathead using the cylinder head, a sleeve that I made on a lathe that slid down the bolt hole with a 1/8" hole in the sleeve's center. I drilled the bolt out using a successively larger series of bits until I could collapse the bolt stub with a punch and unsrew it, then ran a tap to clean it. Worked pretty well, actually, only flatted a little of the thread in the block, still have well over 50% thread engagement at the worst spot, so I think it will take the torque.
My question is about the bit shavings. I was working on the bolt directly above the plug on cylinder #3, second from the back on the passenger side. For the drill shavings that fell down the hole, where did they end up? Is that a blind hole where they can't do any damage or is that in the valve area under the intake manifold? Do I need to pull the intake manifold to clean that up?
Overall pretty satisfied with the process. My 17 y.o. son John helped out, cutting and grinding the dowel pins to help align the head until the bolts could be put in and helping out overall. I can see his skill level and confidence growing. That's nice.
Old Jan 14, 2006 | 11:27 AM
Steve_B's Avatar
Steve_B
I am sure that just goes into the water jacket
I wouldn't think drill shavings will do any harm
Old Jan 14, 2006 | 12:20 PM
AXracer's Avatar
AXracer
If it doesn't go into an intake or the valve chamber, put a magnet down the hole to pick up the chips. Next time coat the drill with a heavy layer of thick grease, and remove clean and recoat often to reduce the number of chips that fall into the hole to a minimum.
Hint: you can magnatize a tool like a screwdriver very easily if needed. Take a couple feet of hook-up wire or a single strand of lamp cord and wrap it around the shank of the screwdriver in a neat coil. The more winds the stronger the magnet that will be produced, but don't overlap or double up. Hold one stripped end of the wire against one terminal of the vehicle's battery, and strike the other end across the other terminal like striking a match. Sparking will occur, but it is harmless. Just do it once, unwrap the wire and test the magnetic property by touching it to a loose steel bolt or screw. If it's not strong enough, try it again with more wraps and/or a harder "strike" across the battery terminal. If that doesn't produce a strong enough magnet, try a better quality screwdriver, the higher the quality of the tool steel, the stronger the magnet will be.
Old Jan 14, 2006 | 02:22 PM
imlowr2's Avatar
imlowr2
I used a shop vac and connected a vinyl clear tube to the end of the hose (use duct tape to seal it). Then just turn on the vacuum and stick the hose in the hole, etc. It works pretty good.
Old Jan 14, 2006 | 03:20 PM
286merc's Avatar
286merc
Since the bolts on a flathead go into the water jacket it is imperative that they be coated with sealant before installing. Permatex #2 Aviation is the accepted choice among builders.
Also coat both sides of the head gasket with either a true aluminum paint in a spray can or the much higher priced auto store similarities. Apply while tacky.
Old Jan 14, 2006 | 05:18 PM
51ford fan's Avatar
51ford fan
Just be real careful striking any spark at or near a battery, 99.9% of the time your ok but a questionable battery gassing off can explode. There were two guys looking at a neighbors car that had been sitting for awhile. One of them was smoking, and they both leaned in to have a look see at the engine. The battery exploded in their faces, not a real pretty sight and that incident really put the fear into me.
Old Jan 14, 2006 | 07:27 PM
Narwhal's Avatar
Narwhal
Great advice, thanks.
What does true aluminum paint mean? Paint meant to put on aluminum or paint tinted with ground aluminum?
Thanks.
Old Jan 14, 2006 | 08:08 PM
286merc's Avatar
286merc
Paint containing ground aluminum. The real cheap stuff is just tinted paint.
Supertommy68
May 12, 2024 05:22 AM
BenS77
Aug 7, 2013 11:50 PM
TrippingCobras
17
Apr 25, 2012 08:58 AM
TX92F150
13
May 9, 2011 07:00 AM
heel&sole
Garage & Workshop
21
Mar 5, 2005 01:18 PM
