V.I.N. location?
Old Jan 14, 2006 | 08:22 AM
chilione99's Avatar
chilione99
Cool V.I.N. location?
hi, bought a 1951 F1. believe it was originally owned by U.S. Air Force.
Can't find a VIN number. frustrated, where to look? Is it possible it was removed on purpose? Any help appreciated. have several years of rebuilding ahead. Would like to get clear title.
Old Jan 14, 2006 | 08:34 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Most obvious place is on a plate attached to the inside of the glove box but some are also stamped on the frame rail and some on the crossmember under the radiator. I could never find a number on my frame rail but there was one on the front crossmember.
Welcome aboard and good luck with your project....
Vern
Old Jan 14, 2006 | 08:39 AM
chilione99's Avatar
chilione99
Thanks. I will check that info today.
Old Jan 14, 2006 | 01:37 PM
kdmcinnes's Avatar
kdmcinnes
Most Likley stamped on the frame. someone told be it was usually on the pass. side under cab, Not 100% sure but what will it hurt.
Happy Hunting,
Kyle
Old Jan 14, 2006 | 04:03 PM
LEckart's Avatar
LEckart
Most of the time the VIN is stamped on the frame just ahead of the firewall on the top of the frame rail on the passenger side.
Old Jan 15, 2006 | 12:47 AM
FordPUs's Avatar
FordPUs
I have my VIn number on the door of my glove box on the inside
and then while I was painting my frame on the passenger side inside the firewall and ahead of the battery box I saw a number and sure enough it matched my number on my glove box, It was on the top of the rail. My pickup is a 50 F-1
so if you find it I would be curious as to where it was at onyour 51?
Old Jan 15, 2006 | 02:00 AM
texan2004's Avatar
texan2004
I believe the 51/52's had a VIN plate on the fiewall like the 48-50's. Also a VIN plate on the glovebox door and stamped on the passenger side frame rail.
Old Jan 15, 2006 | 02:03 AM
texan2004's Avatar
texan2004
FordPU's,
If you get a chance, please take a look at the stick thread at the top of the forum 49/50 VIN # cut-off. We are collecting information on these beyond the cut off to include date on column vs. floor shifts, raised panel vs. flat panel side on the pick-up boxes, etc. Would love to have your info if you would like to participate.
Thanks,
Carl G.
Old Jan 15, 2006 | 10:14 AM
reamer's Avatar
reamer
My '48 F-5 Was built April 28, '48, Sommerville, Ma.
The VIN on mine is stamped on the DRIVERS side frame rail in the middle between the fire wall and the radiator. In plain view (after cleaning the frame)
Reamer
tdmoparguy
Oct 14, 2011 08:17 AM
ALSAIR
37
Jul 8, 2005 08:49 PM
jerryh
1947 and Older Ford Trucks
Feb 5, 2005 07:40 AM
TLD
60
Dec 16, 2003 09:41 PM
kevin71100
Apr 8, 2003 10:50 AM
