1957 F100 Grille on a 1959 F100?
Old Jan 14, 2006 | 04:39 AM
turborscapri1984's Avatar
turborscapri1984
Just wanted to know if it were possible to put a 57' grile/hood onto a 59'. I like the hood of the 59', but the grille of the 57'. Im getting a 1959 F100 tomorrow for my newer F250 and it has some front end damage. I need to replace a fender, the grille and hood anyway so Im exploring my options.
Thanks
-Mike-
Old Jan 14, 2006 | 07:10 AM
Walston's Avatar
Walston
I don't know for sure but here are some thoughts. You may have to change the fenders and gravel pan also. The 59 and 60 fenders had different fronts from 57 and 58. You also may get interference with the hood since the 59 hood dipped down and the 57 was straight across. Good luck
Old Jan 14, 2006 | 12:13 PM
turborscapri1984
OK, kinda what I was thinking. Are the fenders and such hard to get a hold of?
-Mike-
Old Jan 14, 2006 | 04:18 PM
Walston's Avatar
Walston
You can get fenders in the junk yards of the southwest for the 57-60's. They are going faster, but the still exist. John's F100 can also get them for you.
Old Jan 14, 2006 | 04:24 PM
kooper909's Avatar
kooper909
The '57 grille and '59 hood shouldn't have any clearance issues. I think I've seen that combination before.
I believe the '59 fenders, valance, and parking lights will work with the '57 grille. It just won't look the same as '57. If you want the round '57 parking lights, then you'll need to change the fenders and valance to the '57-'58 style.
Old Jan 14, 2006 | 04:38 PM
turborscapri1984
Mainly I like the 57' grille better. So you think it will fit? I dont want to do any drilling or cutting so I can maybe change back later. I was hoping the grilles could just be swapped, but like I said it has some damage and needs new sheet metal anyway.
-Mike-
Old Jan 14, 2006 | 04:50 PM
mr4speedford's Avatar
mr4speedford
57 grille will bolt on, not sure if the headlight assembly just plugs in though since your going from quad lights to just a pair. -4speed
Old Jan 14, 2006 | 04:57 PM
kooper909's Avatar
kooper909
Well I think you could hook up the '57 lights to the plugs for the outer headlights, right? They're both hi/low-beam combos. I guess the high-beam-only plugs would remain disconnected.
Old Jan 14, 2006 | 05:01 PM
turborscapri1984
Talking
Yeah, that should be fairly simple. Anyone know where to get a set of lowering spindles?
dcmania
16
Feb 11, 2017 11:01 AM
SeaCarr
WTB - Parts & other
Aug 26, 2015 11:58 PM
1959 f100
Jan 16, 2010 03:36 PM
pagokid2001
Nov 3, 2009 04:31 PM
birdman1
Feb 15, 2008 09:27 PM
