band-aid fix for C-6
Old Dec 19, 2005 | 08:40 PM
hatemakings/n's Avatar
hatemakings/n
I have a c-6 that wouldn't shift into 2nd gear and when it did shift it started shooting tranny fluid out by the front seal by the quarts. I pulled the tranny and there are no signs of metal in the old fluid. When I went under the hood to remove the top two bolts I noticed a vacum line had come of the carb. I believe I lost vacuum and the only reason the tranny shifted was because of the fluid pressure in the tranny. The front seal needs to be replaced and I reconnected the vacuum line. Do you guys think it would be ok to put a new front seal in so I can drive it 7 miles to put it into stoprage until I get back from Iraq? I'm leaving in less then a month and the towing company wants $55 to tow it that far. I know there may be internal problems and if this fix does work it may make the problem worse but the tranny could use a rebuild anyway and I was hoping to wait until I got back to rebuild it.
Old Dec 20, 2005 | 07:10 PM
bob arrington's Avatar
bob arrington
if it will get to where you want it , go for it ,bob
acerocks666
15
Nov 11, 2016 09:20 PM
lonelypauly
Oct 2, 2012 09:04 AM
musicmanbiker
Jun 7, 2011 02:39 AM
Red92Ranger4x4
1983 - 2012 Ranger & B-Series
May 22, 2011 09:38 AM
Chevy_Monza
Jun 11, 2004 06:28 PM
