Interesting find: Extended cab '40 Ford?
Old Dec 1, 2005 | 12:26 PM
alittle40's Avatar
alittle40
Found this truck on fleabay anf thought it would bear a look by someone who was looking for a truck. Bidding was about $50 today. Check it out for parts! or a project! The hood appears to be off a newer 46/47 truck. here's alink:
http://cgi.ebay.ca/1940-41-Ford-ext-...94221780QQrdZ1
Old Dec 1, 2005 | 07:53 PM
46fordtruck's Avatar
46fordtruck
Looks like it might be a good starting point, if the work was done correctly. The hood is actually from a '40-'41 big truck, as is the grille...wonder if the frame is from a bigger truck or it's a 1/2 ton.
Old Dec 1, 2005 | 08:15 PM
gdawghereiam's Avatar
gdawghereiam
did that come from the factory that way or was that added on?
Old Dec 1, 2005 | 08:58 PM
46fordtruck
That is a custom thing, there were no factory extended cabs made. Not sure of any aftermarket body mfg making extended cabs back in the '40's. You make these extended cabs by using the pieces from another cab. A guy around here has a 4 door '46 Ford pickup, used 2 cabs, and 6 doors to make it all.
Old Dec 1, 2005 | 11:07 PM
45ford's Avatar
45ford
Looks like a lot of mud around both rear side windows. The sheet metal is fairly rusted and it probably extends under the mud.
If you bought it, you'd soon find out how good the metal work is, as all the mud should come off.
Mike
Old Dec 2, 2005 | 09:04 AM
3Mike6's Avatar
3Mike6
Wow, I've bought some "project" vehicles in the past, but this one looks to be a large undertaking.
I wonder if Chip Foose and the A team could turn it around in 7 days?
Old Dec 2, 2005 | 09:56 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Cool looking old truck...but a lot of work to finish. The price is right.
Vern
Old Dec 2, 2005 | 09:39 PM
1952henry's Avatar
1952henry
There were some companies, such as Proctor-Keefe that custom-made crew cabs and sleeper cabs for Fords (and probably others) in the 30's-40s.
Old Dec 4, 2005 | 03:20 PM
alittle40's Avatar
alittle40
There you go, now we have it on good authority that they did make crew cabs back in the 30's and 40's. Now with 90% perspiration and 10% inspiration this would make it a good project. A person could always make it back in to a conventional cab. The hood does look a little funny sitting up there, but you could always add a few filler panels to match it to those fenders. Using a 55 gallon drum of sculpting paste anything is possible. This won't become a 'belly-button' truck which it seems everyone wants to make these days. Even Chip would require more than seven days to complete this project. Jessie could pull it off but it wouldn't look 'stock', but it would have a hell of a nice exhaust system. Loud too!!! Maybe someone with a PhotoShop program could smooth it out and show us what it could look like. Happy dreams.
Old Dec 4, 2005 | 08:44 PM
46fordtruck
There would be no need for anyt filler panels for the fenders, it appears the fenders on the back of the truck are the stock big truck type fenders, which will match up perfectly with the big truck hood it has sitting on it. A '40-'41 big truck with an extended cab would make a neat truck, certainly won't see any like it. But the amount of filler used is something that would have to be investigated further.
Looks like it probably won't sell, it's still got 24 hrs left, and only 1 bid. Perhaps the amount of filler is scaring off potential buyers.
willowbilly3
1947 and Older Ford Trucks
16
Oct 31, 2015 10:06 PM
Mixer man
Sep 10, 2015 07:51 AM
daddylee100
Dec 17, 2014 06:57 PM
51504BAT
Aug 28, 2014 06:57 PM
scott79
May 14, 2013 10:13 AM
