aftermarket guages?
Old Aug 7, 2002 | 01:30 AM
wayne_j's Avatar
wayne_j
aftermarket guages?
Old Aug 7, 2002 | 05:10 PM
cjcathey2002's Avatar
cjcathey2002
aftermarket guages?
i have been looking at getting a set of aftermarket guages to intal on top of my dash, the set that comes with the oil pressure, water temp and a volt meter. has anyone ever installed the electic guages? does the set come with the sending units and instructions on where to place the senders? also i want to install in on the dash just behind the dash pad on the metal surface, anyone done this? i want to see them when i am drving and not have to look down to seem them. thanks.
1977 F250 460
C6 Hedman Headers
Dual 40 series
edelbrock performer
holley 4150
msd 6a and blaster coil
Old Aug 7, 2002 | 05:26 PM
tellico racing's Avatar
tellico racing
aftermarket guages?
The senders will go where the original senders are in your block.Hooking the volt gauge up will require some wiring. The instructions should have the diagrams to show you how to hook it up.
78 F150 4x4
429 CID
Dana 44 spooled Front,
9"Locked rear,
5:13 Gears
17/40/15 Gumbo monster mudders
18/39.5/15 Swamper Boggers
BIG,BAD,and UGLY.
Old Aug 7, 2002 | 07:59 PM
fatdaddy's Avatar
fatdaddy
aftermarket guages?
I used 4 of the 2 5/8" , white face , autometer gauges , and mounted them in groups of 2 on each side of the ash tray , i don't smoke and don't care about the ash tray so-----they are(left to right)---water temp--oil press.<<<<ash tray>>>>vacuum----voltage , the voltage is the only electrical gauge out of the four----I mounted them under the dash and just bent the mount up alittle so they were very easy to read , although i still have to look down alittle and too the right but its no biggie.........I absolutely love my big face gauges---I am constantly in touch with the how the motor is running----no guessing for this Texass Fat Boy-----I wish I had a temperature gauge for my girlfriend----I just don't know where to MOunt the Sending unit---Whoa Doggies----It sho is hot dis time of da year!!!!!fd :-X11
Old Aug 7, 2002 | 08:33 PM
Ford79's Avatar
Ford79
aftermarket guages?
Here's a pic of my guage install. I have the 2 5/8 face Autometer guages as well. Mine are mechanical with the exception of the volt guage. I had to disassemble the whole dash in order to mount the guage pods. https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=6034&.jpg
Old Aug 7, 2002 | 09:02 PM
fatdaddy's Avatar
fatdaddy
aftermarket guages?
That is an ideal location for gauges----I just didn't want to suffer as much as You did!!anyway , I'm happy with my under da dash mount---because all the cabeling is alot easier to hookup initially , but , even more importantly , IFFFF I have to diagnose a problemOOO I can just grab and pull it out from under the dash---I would rather not,I will not waste all that time dissasembling my whole dash just to find a loose connection , I would never get all that crap back in and hooked back up and functioning correctly , a real Witches hairnet.................fd
