fuel Question
Old Sep 12, 2005 | 06:42 PM
cbfomoco's Avatar
cbfomoco
fuel Question
Ok I have a 292 with a motorcraft 4300 4bbl and a after market replacement fuel pump. both are revelitve new and if started weekely work great. but if it sets for a couple of week I have to crank forever to get fuel back up to the carb. if i put a fuel presure reg on would this help? is there anything i could do to help this problem?? or is that just the nature of the beast? thanks
Old Sep 12, 2005 | 06:49 PM
Christopher2's Avatar
Christopher2
Veteran: Navy
I have the same problem, I think the fuel is evaporating from the carburetor. My truck is a 1977 F150 with a V8.
Old Sep 12, 2005 | 07:22 PM
Randy Jack's Avatar
Randy Jack
Ditto what Chris said. Fuel evaporating is the "nature of the beast". The only other cause might be the fuel draining back toward the fuel pump, but that requires that the pump have a leaking diaphragm or valve. If it's fairly new, that is unlikely.
Old Sep 12, 2005 | 07:25 PM
WillyB's Avatar
WillyB
On the big grain trucks and the like we used to add an electric fuel pump that ran off a pushbutton on the dash. You would "prime" the truck before you started it. Ford even had one stock on their big industrial V8s.
Old Sep 13, 2005 | 12:14 AM
51ford fan's Avatar
51ford fan
I had the same problem on a 292 I put in a 46 Ford pickup years ago. At the time I thought it was a bad pump, so I installed an electric fuel pump. It started ok after that, and for the rest of the time I owned it.
Rod
Old Sep 13, 2005 | 12:41 AM
ALBUQ F-1's Avatar
ALBUQ F-1
This can also be because of a leaking power valve gasket. To check, pull the top of the carb loose after the engine has cooled, and watch the level. (leave the cover on but loose) Once the engine has cooled there should be little evaporation going on. On the Holley 94's (flatheads) this is common as dirt, the shape of the newer (replacement) power valves is different at the seat than the old ones, and a special gasket is needed to properly seal the power valve to the body. A bad gasket will drain the bowl almost overnight, and it all ends up down in the manifolds and cylinders, not a good situation at all.
The best gasket to use is an AN crush washer made of tubular copper, AN 900-8 (1/2" I.D.) .
hardwaterfreak
Nov 16, 2011 01:06 PM
dws57
Modular V8 (4.6L, 5.4L)
May 2, 2010 11:11 AM
poston
Sep 19, 2006 09:49 PM
ssnh
General Diesel Discussion
Jan 20, 2006 09:17 PM
a_borg
May 23, 2003 07:11 PM
