Plugged in truck how much curent draw??
Old Aug 30, 2005 | 12:38 AM
blessteve's Avatar
blessteve
I need to know how much current does 7.3 draw when plugged in?
Also how much power?
If I am hunting and my glow plugs die I will have to plug my truck into my (soon to get) generator.
Portable generators are rated for how many amps and watts they put out.
Thanks for a great web sight I have learned a bunch here!!!!
Old Aug 30, 2005 | 07:00 AM
tjbeggs's Avatar
tjbeggs
i have been told that they pull about 1000 to 1200 watts. not sure about amps
Old Aug 30, 2005 | 07:40 AM
westpsd's Avatar
westpsd
Amps = Watts / volts
1200 watts / 120 volts = 10 amps
Old Aug 30, 2005 | 11:14 AM
blessteve's Avatar
blessteve
Thank you that helps out alot.
Looks like I will get a 2000w 15amp generator
Old Aug 30, 2005 | 11:23 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
That doesn't leave much room to run anything else. OTOH, it only takes an hour or so to heat the truck. Should work fine.
