When you repair it, run a cup full of Dawn dish washing detergent in the radiator with clean water. Let it come to temp, drain, flush, & repeat. This will clean the oil from the system. The oil will turn ALL rubber hoses to mush!
Thanks for the replays. I was thinking the same things. My problem started out with just a little bit barley noticeable in the tank. Went to the mountains and the next day had an amount floating on top of the tank to cover the top of the anti freeze. Went to the dealer today for an eval. They immediatley started throwing out the injector cups leaking by. Course they estm. about $4000 for the fix. does this amount seem hight?
If they have to pull the heads maybe $900 to $1200 in labor and $500 to $750 in parts using old injectors. With new or reman injectors it could be $4000. If it is running fine just oil in the coolent I would try the oil cooler first. It the most likely cause and the cheepest fix. Three hours labor tops and $300 in parts top.
Looks like the cooler was the problem. Thanks for everyones help.
Did you get the oil thoroughly flushed out? The petroleum with swell the coolant lines from the inside out. It softens the rubber and then they fail over time.
So how did they find the problem put air pressure to the oil cooler and look for bubbles? Also how did they fix it take radiator apart change out cooler in tank? Just curious.
LPR
As for the flushing, I filled it contless times with water and dish soap. Brought it up to operating temp. Circulated it for a few minutes, let cool and drained. Hope it was enough.
