Towing my Powerstroke?
Old Aug 14, 2005 | 06:53 PM
96ExtracabPSD's Avatar
96ExtracabPSD
Hello all. I am driving a truck with a 40 ft bellydump hooked on it this summer hauling asphalt on highway construction projects. So far everything has been close to home but in a few weeks we have a job to do about 250 -300 miles from home and I want to hook my pickup on the back of the belly dump trailer and tow it up there so I have some wheels. I checked and it looks to be legal to do, so I have a couple questions. My Ford is an automatic, so do I just put the transfer case in neutral? Can I unhook the batterys and just leave the key on to unlock the steering wheel? Any other precautions that I need to know about?
I will make a couple lights that I can stick on the bumper and the belly dump is already wired for a trailer so that should take care of lights. I doubt the weight of the pickup will be noticeable under braking since the light weight on the truck and trailer is 36,000 lbs. Prolly never know it's back there, just won't be able to back up.
Any pointers or insight would be appreciated. Thanks.
Old Aug 14, 2005 | 07:43 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
You might exceed the maximum total length allowed for vehicles. Check with your state DMV for this and you might need to have working brakes - check again with DMV. You probably should take the driveshafts off. I don't think it is reccommended to tow this pickup a long distance. Check with a ford dealership on this.
Old Aug 15, 2005 | 07:39 AM
mistakenID's Avatar
mistakenID
If your company pulls doubles the trucks are most likely already licensed for over length, your company will know. You can pull the truck with the transfer case in neutral but personally I'd drop the rear driveline if I was going to pull it 300 miles.
Couple other things to consider. Insurance? Will the company insurance or yours cover the truck if something happened? Flying crap from behind the trailer is a consideration. Make sure the trailer is as free from dirt and rocks that like to hide in bellydumps. There's a lot of small stuff trucks and trailers suck up and with your pickup that close behind it'd be a good idea to put some cardboard or something in front of the radiator. Windshield "should" be ok but you never know
Old Aug 19, 2005 | 02:18 PM
Leader's Avatar
Leader
You going to make a tow bar for it or use a dolly? If you have the rear axle on the ground, unhook the driveshaft. You seem to have the right ideas about the rest. Rig up lights, your brakes will do just fine. Nobody is going to question you about anything if you don't do something stupid & get stopped.
Mike F250
May 22, 2012 06:02 AM
mikwar
Nov 10, 2009 08:33 PM
Ding
Nov 6, 2005 07:18 PM
four-sixty-power
Apr 19, 2005 05:32 AM
boarder
1983 - 2012 Ranger & B-Series
Mar 21, 2005 07:52 PM
