Work platform suggestions
Old Nov 10, 2009 | 12:17 PM
mikwar's Avatar
mikwar
Been reading the helpful info on this site and notice (or did not notice?) any sugestions on a platform for getting comfortable access to engine bay work. Dang hood latch leaves a "Big belly imprint" which other half thinks I have a mistress on the side . Couple times had a footstool slip out from my footing and leave a belly scratch as well. I am 6' 1" and a regular beer belly kinda fella LOL Been tempted to make a mobile home kinda platform so can reach down in engine bay comfy. Any suggestions?
Old Nov 10, 2009 | 02:53 PM
tdappleman's Avatar
tdappleman
These are tough to work on - I've actually been known to sit inside the engine on top of the radiator support. I'm sure I look 'special' but it at least allows me to get to all of the plugs, intake, etc. They do make steps which mount on the tires and ones which mount in the license plate location. I've not tried either on my Excursion but do have a couple of customers with conversion vans who have the license plate steps and they work nice. The sturdiest would be something which could mount into a hitch receiver if you have a front hitch.
Tire mount: Thule Step Up Wheel Step - Tire Mount TH232 : Trailer hitch bike rack and trailer hitches - etrailer.com
License plate mount: Fold-A-Way Deluxe 2-Level License Plate Step Car, Truck, Motorcycle: Compare Prices, View Price History and Read Reviews at NexTag
Hitch mount: Hidden-Hitch Front Receiver Hitch Accessories | Step & License Plate Adapter | Hidden Hitch
The only other thing I could think of would be a small deck - basically something you'd drive up to and then have a raised work platform. A bit of a pain to do and hopefully you don't have to work on your Ex that much! Hope some of this helps.
Old Nov 10, 2009 | 03:25 PM
jsimon724's Avatar
jsimon724
Do a search for "topside creeper" ( I think that's what they're called). Basically a mechanic's creeper and small step ladder in one. Let's you lay on the creeper pad over top your engine and work from the top down. Take a look, you'll see what I mean.
Old Nov 10, 2009 | 03:31 PM
jdadamsjr's Avatar
jdadamsjr
Good links td !
but glad I don't have to work on mine a lot....
I would worry if the license plate step is strong enough for us healthy guys
and KNOW on my 05 EB the mount is in plastic
I have seen a dolly in the shape of a LARGE C that basically rolled under the engine and had a surface to climb on oer the engine..... let me see if I can find that link...
this is not it, but will give you the idea - not cheap
http://www.jcwhitney.com/HYDRAULIC_L...2007580;true;0
Old Nov 10, 2009 | 04:32 PM
tdappleman's Avatar
tdappleman
Topside creeper - I've seen them and couldn't think of what it would be called. I like it!
Top Side Creeper 1-00019 - Topside Creeper Adjustable Overhead Creeper - Quadratec
Old Nov 10, 2009 | 06:15 PM
m350's Avatar
m350
I would think a Guy could make a setup that would hook right into the front tow hooks,,a couple of mounts, to Hook through them,,,with a bracket to mount a 2x10 or
2x12, so,,,you could have a plank platform to walk on,,,,maybe a leg on the corners,,depending on what a man wants,,,be pretty easy to make.
When we did my sons F-150 plugs we put a blanket on the radiator support/grill area,,layed a pc of 1/2" or 5/8" plywood from the rad support to a 4' high old Book case/shelve unit(any kind of rugged frame,,,pallet, etc),,with a 4 foot step ladder he could climb up,,lay there comfortably,,,slide into the engine bay as needed,,,No broken Grill parts,,,No banged up/hurting knees,,with an assistant,,,(me),,handing him tools,,worked great!
Old Nov 10, 2009 | 08:33 PM
dsquared's Avatar
dsquared
[quote=m350;8129212]I would think a Guy could make a setup that would hook right into the front tow hooks,,a couple of mounts, to Hook through them,,,with a bracket to mount a 2x10 or
2x12, so,,,you could have a plank platform to walk on,,,,maybe a leg on the corners,,depending on what a man wants,,,be pretty easy to make.[quote]
Something like this????
https://www.ford-trucks.com/forums/8...ooks-step.html
ChalmersP
May 30, 2017 09:03 PM
kaeden1100
Mar 5, 2017 01:26 PM
LindenBruce
Feb 3, 2017 10:50 PM
mudmagnet63
Aug 10, 2016 06:04 PM
Ben FORD
General Diesel Discussion
Feb 26, 2012 04:32 PM
