Sponsored by: Auxito
F150 fires...help!!!
Old Aug 14, 2005 | 06:26 PM
loaferoatan's Avatar
loaferoatan
For some unknow reason i glaced at my parked truck which i hadn't driven since last night and it was ON FIRE!!!!!!!!!!!!!!!!! after a brief panic the fire was put out and now i'd like to know why? the master cylinder is shot. is this where the cruise control switch is located? what can i do now? if it is a defected part will ford pay for my repairs? any help will be GREATLY appreciated.
p.s have pictures of where the fire took place if anyone needs to look.
Old Aug 14, 2005 | 06:30 PM
seldont's Avatar
seldont
It is the swith that disengages th cruise when the brakes are applied. The circuit is hot all the time. Should they fix it?? Yes.... Will they??? Who knows??? I have a feeling there are going to be lots of lawsuits over this before it is over.......
Old Aug 14, 2005 | 07:43 PM
LxMan1's Avatar
LxMan1
This recall has been out for some time now. They may not fix the truck if it hasn't been repaired by now.
Old Aug 14, 2005 | 08:15 PM
loaferoatan
as far as i knew my 1997 F150 was not part of the recall...just 2000-2003
Old Aug 14, 2005 | 08:44 PM
LxMan1's Avatar
LxMan1
You may be correct on that. I have read conflicting reports on what years are covered. I know that all 2000' s and the 2001 (Super Crew only) are covered. I'm not sure how far back is covered though.
Old Aug 15, 2005 | 06:20 AM
bigdaddyII's Avatar
bigdaddyII
The 97s arent covered yet. They may or may not cover it, good luck though. When the recalls came out I went ahead and changed my switch chalking it up to $20 is cheaper than the whole truck and besides, if a recall ever does come out than I will get reinbursed and everyone said I was nuts, Thanks for proving that I am not. I sleep better at night knowing that I did everything I could to cover my azz.
Old Aug 15, 2005 | 06:59 AM
lardman's Avatar
lardman
Call your insurance and file a complaint on the nhtsa website.
Old Aug 15, 2005 | 12:49 PM
Deebo's Avatar
Deebo
I have a 01' crew that goes in friday for the replacement switch. So I know the 01' model is involved.
Old Aug 15, 2005 | 02:02 PM
fordguy21's Avatar
fordguy21
bigdaddy I did the samething after checking the switch and it had fluid all over it, so I disconnected it and finally the dealer had them in stock and like you said $20 better then having no truck
Old Aug 15, 2005 | 09:47 PM
jeffchickering's Avatar
jeffchickering
Can someone shed a bit more detailed info on this issue? I have a 1998 F250 with the 5.4L, and am VERY interested in this. I'll gladly spend $20.00 if needed.
How do I tell if mine has been fixed ( I bought it used)
Old Aug 15, 2005 | 10:15 PM
paul812's Avatar
paul812
can someone post a pic of this switch or give an accurate descr. of where it is located, how many wires is in the connector, etc.? i have '01 also, but not s'crew. i dont see what the diff would be in the cab configuration, but i have not recieved a recall notice yet...thanks ..paul
Old Aug 15, 2005 | 10:27 PM
LxMan1's Avatar
LxMan1
Only the SuperCrews were recalled in 2001. They were made at a different plant with a different switch supplier.
It is located on the front of the master cylinder and has a 2 wire plug on it.
Old Aug 16, 2005 | 12:42 AM
fordguy21's Avatar
fordguy21
heres a link with an illistarion of the switch.
https://www.ford-trucks.com/forums/showthread.php?t=3372...ad.php?t=337223
Page 4 post 51, but good to read through who thread
hope this helps
Old Aug 16, 2005 | 04:53 AM
TheDuck's Avatar
TheDuck
Ford.com has a "owners" site where you can enter your VIN and it will tell you if there are any open recalls for that VIN. You can also go to www.flatratetech.com, to the Ford forum and ask someone there to run a Oasis for you. With Oasis your vehicle will show any repairs done by Ford as well as all open and closed recalls. You will have to post your VIN for this as well. The Ford owners site works great for just checking for recalls and you know right now, with flatratetech you will have to wait till someone gets a chance to run it for you and then post it.
Old Aug 16, 2005 | 01:18 PM
loaferoatan
After researching the problem it can happen on some models from 1992 but for F150s from 1996 are the most at risk. Ford is not claiming any responsiblity telling people to call their insurance company. As for the three people that have died so far because their truck or expedition caught fire in their garage, there is a law suit in the works, but Ford is saying it's not their fault ( which i guess they must ) but watching my truck spontaneously catch fire it is a serious defect. if you have a 1996-2003 ford, better go to the dealer and pay the $23 and get the CRUISE CONTROL SWITCH replace. you'll sleep better. as for me i have't pay about $1K to replace all the wires and master cylinder. THIS CAN HAPPEN AT ANT TIME!!
