secondaries not working on 4180
Old Jul 5, 2005 | 12:13 PM
Rmvr53's Avatar
Rmvr53
rebuilt the carb as I had a flooding issue (fixed) but prior to the rebuild, the secondaries didn't work. New diaphram installed (made sure no leaks) but still they don't work. Unless this is an easy fix of something Im missing, can I convert to mechanical secondaries as opposed to vaccum?
thanks
Bill
Old Jul 5, 2005 | 02:30 PM
Ford_Six's Avatar
Ford_Six
Are you just checking by revving the engine while watching the secondary linkage? There has to be a load on the engine for the secondaries to open.
Old Jul 5, 2005 | 04:14 PM
Rmvr53's Avatar
Rmvr53
yes...thats what Im doing - just reving it up.... if thats the case (needs load) then I'll go drive it and see whats hap'n when I get home
thanks!!
Bill
Old Jul 5, 2005 | 11:03 PM
LxMan1's Avatar
LxMan1
Yep, it must be under a load. They open by the vacuum signal being drawn thru the front barrels.
Old Jul 23, 2005 | 10:43 PM
dalejrfan's Avatar
dalejrfan
i had the same problem, and went to a lighter spring under the diaphram on the vacuum secondarys this will cure your problem it did for me 85 f250 4x4 351
Old Jul 25, 2005 | 07:11 PM
ClydeSDale's Avatar
ClydeSDale
I just returned from a 2200 mile trip to and around Colorado. I'm still kicking myself for not having the carb rebuilt before we left, but part way down I began to have serious doubts that my 4180 secondaries were working properly. With the last rebuild I had the quick change spring adaptor installed, changed to a lighter spring and had had it working good, but it didn't seem right now At a campground in NW Kansas I ran into a great Canadian guy who was working the wheat harvest with a custom harvestor crew. He started talking to me about how nice it was to see an old truck actually working and when I shared my concern about the carb he showed me a little trick.
I swung into an implement dealership (hardware store would've done too) and got a short #6 machine screw, a couple washers, a nut and a lockwasher. As he'd instructed, I put the washered screw into the slot on the driver side of the secondary carb linkage, slid on the washer, lock and nut and adjusted it so the primary linkage rod that runs in the slot would contact the washers at ~1/2 throttle to start with. After a couple of adjustments I got it so the secondaries started opening about where I wanted them. They didn't open all the way mechanically but I felt it was better than nothing. If the secondaries were working with vacuum this made it a sure thing and the vacuum would do the rest. Did the rest of the trip running what I now call the "Trevor Modification".
It may not be totally "kosher", but it works.
Roger
Clyde S Dale, my chestnut brown & tan 5th wheel workhorse is a
1984 F250HD XLT RCLB 4X2 8600 GVW
460 C6 3.55's
67,500 original miles (and counting)
Old Jul 25, 2005 | 07:24 PM
Ford_Six's Avatar
Ford_Six
Yeah, that's the cheater screw mod. Really not the best thing to do, if you stomp on it the secondaries pop open uncontrolled and the mixture goes way lean.
Old Jul 25, 2005 | 07:42 PM
ClydeSDale's Avatar
ClydeSDale
Any non-factory modification has risks, but for working instead of "show boating" it worked just fine. Not too often do I "romp on it" when pulling a fifth wheel
Old Jul 25, 2005 | 08:38 PM
LxMan1's Avatar
LxMan1
As long as you ease into the secondaries slowly, it will work, but without the accelerator pump in the rear, if you open it too fast, it will lean out and bog severely causing a backfire and blown power valve.
Old Jul 26, 2005 | 11:13 PM
Rmvr53's Avatar
Rmvr53
and I can tell ya about blown power valves...finally had the chance to rebuild my 4180 2 weeks ago. Power valve rotated on its shaft! needless to say I found my flooding problem. I followed the above advice and I "think" the secondaries are working - sounds like it (I think) will have to get out on the road proper to try it
Bill
