39 truck no run need help
Old Jun 27, 2005 | 11:52 AM
otto1's Avatar
otto1
I just picked up a 1939 1.5 ton truck the engine truns over great I set the points checked the plugs but I have no fire I swaped out the coil still no fire.
how do I hot wire the engine to run with out the wireing from the truck?
any help would be great.
Dan
Old Jun 27, 2005 | 11:39 PM
mtflat's Avatar
mtflat
Start at the battery and trace your power. Battery, solenoid (small wire to ignition), ignition switch, coil IN and OUT (with key in run position).
How did you 'set' your points? A 39 should have a crank mounted distributor and needs to be adjusted on a bench......... Or do you have a later engine with the dist on a stalk like a more modern engine?
asmith6
Feb 14, 2024 09:18 AM
Lazarus88
Apr 14, 2016 07:48 AM
codymartin1988
Modular V8 (4.6L, 5.4L)
Jan 25, 2016 05:49 AM
ky94f250
May 22, 2014 09:32 PM
leov5
Mar 13, 2003 11:12 AM
