Power Windows (1986 F-150 4WD)
Old Aug 9, 1999 | 12:32 PM
Bob_1's Avatar
Bob_1
I'm having power window problems. The driver's side only hums and the passenger's side will not raise at all. How much trouble would it be to convert to manual windows? Any ideas?
Thanks,
Old Aug 9, 1999 | 07:41 PM
ray;
Guest
Posts: n/a
It would be easier to fix the gear boxes on your units. Pull the motors and disassemble the gear boxes. You will find three small plastic rolls that have failed. Replace them with same diameter pieces of pipe, reassemble and your problems are solved. If you do not want to "fix them yourself" buy rebuilt Power window motors and gear boxes for them. I have heard you can buy rebuilt ones but I never had to. About an hour per side. Luck,
ray
Old Aug 10, 1999 | 12:46 PM
Dean's Avatar
Dean
I recently went through this myself and can say that it is not a bad job at all. On my particular truck, I had frozen motors. I simply disassembled the driver's side, cleaned it, and replaced it and all is fine. On the passenger side, I bought a rebuilt motor at Autozone for $59 and it works well.
Be careful about the sheet metal. I got some nasty cuts on my hands from reaching inside the doors.
Old Aug 10, 1999 | 06:24 PM
Kevin's Avatar
Kevin
Yup... if your motors are turning, and the drive gears are gone, it's just a matter of finding a parts store that carries HELP! products. These are the odd-ball parts that should be stocked by your parts store, but end up being a dealer item. For my 86 F150, the motor was fine, the plastic drive unit was trash. HELP! has a repair kit with just those parts that I needed. Check it out... maybe just a few hours behind the door panel and you're on you way again.
Old Aug 10, 1999 | 06:33 PM
Kevin's Avatar
Kevin
bigcrunch
Jun 13, 2017 06:24 PM
Jeff heine
Dec 18, 2016 04:42 PM
wrhatt
1978 - 1996 Big Bronco
Jun 28, 2016 02:15 PM
Kamstutz
May 9, 2015 04:54 PM
1_Bad_X
Aug 27, 2006 02:56 PM
