1945 1/2 ton ford p/u >>Brake pedal assembly<< ???
Old Apr 22, 2005 | 07:03 AM
biglee's Avatar
biglee
Hi All,
Still working on my 45 p/u.
Can't beleive how long it takes to build one of these pickups.
And the money involved . Whew!!!
Anyway, I am about ready to set up my brake system and I need to know what vehicle to use to find my BRAKE PEDAL ASSY.
I will have GM 4 wheel disc brakes.
Would a GMC G20 full size van work good on this application or do I need to go with like a full size chevy pickup truck ?
I know most of you have done something in this order.
Please let me know what to use,IE (what vehicle to rob from a bone yard).
I used a 1991 GMC G20 full size van steering column,and it is a perfect fit for the length,and it came with 2 swivels at the bottom. I have to rebuild a mount to bolt it to under the dash yet,but this is normal for refabing these ole trucks.
I used a 1979 camaro front stub on the front and a 1980 t/a 10 bolt rear axle w/disc brakes.
Thanks all,
Lee
Old Apr 29, 2005 | 10:57 PM
alittle40's Avatar
alittle40
If you want to keep the firewall clean, go with a Kugel style. It turns the master cyliinder 90 degrees to the pedal, 70's Dodge vans had them. If you are looking for a compact unit try a 76 - 80 Ford LTD ll . It has a 9 inch booster and large capacity master cylinder with proportioning valve. Go to Master power brakes website to get some good brake information.
majestek12
Sep 16, 2015 02:06 PM
KIOTI
May 16, 2015 11:57 AM
Jippah
15
May 14, 2014 05:46 PM
351Cleveland C4
The Next Generation
23
Sep 23, 2013 06:00 PM
MP&C
Jan 5, 2009 12:56 PM
