1940 V8 lost compression
Old Apr 28, 2005 | 05:40 PM
CaptivaRay's Avatar
CaptivaRay
I have a 1940 fire truck with a flat head V8. I had it in the shop for almost a year doing some restoration work. Now it has 2 cylinder, exactly opposite of each other, with zero compression. I'm thinking frozen rings, could it be anything else? I have put plenty of PB Blaster and still not free it up. I find it odd that the 2 cylinders are opposite of each other.
All other cylinders have 100 lbs, (+or-).
Ray
Old Apr 28, 2005 | 09:30 PM
51ford fan's Avatar
51ford fan
Ray, it sounds like the valve seats may have come out of the block holding the valve open. If so, the block might be cracked from the cylinder to the valve pocket. I was doing some reasearch, and an article I was reading said the use of unleaded fuel without lead additive causes the valves to weld themselves to the seat. I Don't know if there is any truth to that statment. The internet is full of articles that say straight unleaded in a street Flathead won't cause any problems. I was thinking of building a Flathead for my 51 but I'm so confused I'm not sure if it's the most cost effective way to go or not. Good luck, there sure seems to be a lot of guys with similar problems asking questions right now.
Hope this helps
Rod
Old Apr 29, 2005 | 10:28 AM
JCPSME's Avatar
JCPSME
If you've put lube in the cylinders with no change in compression then it's a valve problem. They are stuck open maybe a little corrosion on the stems or seat problems like 51 said.
Jeff
Old Apr 29, 2005 | 08:03 PM
51ford fan's Avatar
51ford fan
When I first tried starting my 51 Flathead 6 after it had been sitting for 15 years several of the valves were stuck open. I tool Marvel Mistery Oil and mixed it with trans fluid and dumped it in all the spark plug holes. I then turned the engine over to make sure the fluid got into the valve ports. I then left it sit for a week, it took a little more coaxing but they finually freed up. It's my daily driver now and runs great.
Old Apr 30, 2005 | 07:06 AM
CaptivaRay's Avatar
CaptivaRay
Thanks for the tip, I'll try it.
CharlieLed
Feb 14, 2016 09:32 PM
Fomoko1
May 25, 2010 06:43 PM
E30tdf
Feb 8, 2010 10:25 PM
jbarnes
New Member Introductions
Nov 1, 2009 07:58 PM
fbushby
1947 and Older Ford Trucks
Dec 20, 2002 10:48 PM
