OK on a 2003 expedition I removed the rotor>>or tried to>>>Only way I could remove it witout the help of a manual was to remove the 4 bolts from behind the rotor which left the bearing assy in place on the rotor itself>>> I want to get the rotors turned down BUT the bearings do not want to come out...I removed the snap ring but this did not seem to help..
Is there some trick to this or should I just put the assy on a press??
Mine came right off my 03EB...is yours a 4x4? How many miles are on your 03? Most guys are only getting 30k to 40k on orig rotors. Not enough material left to machine them...must replace
