thanks for the information mine is3.25 .I want to change the gears from 3.55 to 4.56 because it has 33" and i carry alot of weight. One of the local shops told me I would have to change the carrier/spool as well. is this true and if so any idea's
Yes, whenever you pass the carrier break you must also upgrade to the next carrier.
I'll have to do the same thing to my '77 when I do a gear change. The rear end should be fine. I know that the 9" rear's carrier break is 4.56(meaning you can go to a 4.56's, but no lower), but I'm not sure about your truck. Though I would assume that 4.56's would be fine.
