axle ?
Old Mar 19, 2005 | 10:01 PM
plod's Avatar
plod
axle ?
I have a 1990 f250 with 300/6 . How do you tell if the front axle is a d44 or dana50
Old Mar 20, 2005 | 08:18 AM
fords_forlife's Avatar
fords_forlife
from what i've seen d50's are leaf-sprung
FORDS_FORLIFE
Old Mar 20, 2005 | 11:12 AM
Dave Sponaugle's Avatar
Dave Sponaugle
The both have leaf springs in a 250.
The 44 has about a 3" diameter lockout hub on it.
The 50 is much larger.
I need to measure mine again as I can not remember if it is 2.75" or 3.25" right now.
Another thing that may clue you in is the cab.
Regular cabs tend to have a 44.
Extended and crew cabs tend to have the 50.
My 86 regular cab diesel has a 44.
My friends 87 extended cab has a 50 under a 351 gas motor.
Old Mar 21, 2005 | 12:59 AM
plod's Avatar
plod
thanks for the information mine is3.25 .I want to change the gears from 3.55 to 4.56 because it has 33" and i carry alot of weight. One of the local shops told me I would have to change the carrier/spool as well. is this true and if so any idea's
Old Mar 21, 2005 | 09:14 AM
77300i6's Avatar
77300i6
I believe that the carrier break for the D44 is 3.73:1 gears.
Old Mar 22, 2005 | 08:49 PM
plod's Avatar
plod
does this mean as well as gears I need to find a different carrier ? I.m just learning as i go
Old Mar 23, 2005 | 07:46 AM
77300i6's Avatar
77300i6
Yes, whenever you pass the carrier break you must also upgrade to the next carrier.
I'll have to do the same thing to my '77 when I do a gear change. The rear end should be fine. I know that the 9" rear's carrier break is 4.56(meaning you can go to a 4.56's, but no lower), but I'm not sure about your truck. Though I would assume that 4.56's would be fine.
Old Mar 23, 2005 | 10:49 PM
plod's Avatar
plod
thanks for the info. my rear axle is a semi floating 10.25 with a factory limted slip hopefully its the same idea as your 9" and splits at 4.56
